sdsurf Posted April 20, 2009 Report Share Posted April 20, 2009 My '72 521 was born with an electric choke. If I put a weber DGEV on it will the wires from the stock electric choke work on the weber? Quote Link to comment
datzenmike Posted April 20, 2009 Report Share Posted April 20, 2009 Yes it should. Quote Link to comment
banzai510(hainz) Posted April 20, 2009 Report Share Posted April 20, 2009 I believe you have to put a female blade connector on there as the datsun uses a barrel /Bullet type plug end on there. what you can do is make the blade to male barrel to fit in the datsun harness so you dont have to cut the stock wires if thats what you want. as the 521 12volt wire comes from the firwwall/wiper motor area. Quote Link to comment
ggzilla Posted April 21, 2009 Report Share Posted April 21, 2009 Yes it will work fine. I had that setup in my Datsun for a couple of years. Quote Link to comment
