Lozer Posted April 20, 2009 Report Share Posted April 20, 2009 (edited) if anyone has wastegate and wants to let it go cheap to a good cause (l20b-T) and is close to san francisco. let me know Edited April 20, 2009 by Lozer Quote Link to comment
sssr20det510 Posted April 20, 2009 Report Share Posted April 20, 2009 where are the pics of this turbo kit your working on Quote Link to comment
Lozer Posted April 20, 2009 Author Report Share Posted April 20, 2009 it's ghetto fantaboulous :lol:i picked it up and had to rebuild the turbo (corvair 180hp)(12 psi max) now i've got to rebuild it again (oil leak) has a side draft webber (pointed right at the wiper motor) It dosent have an internal waste gate so im thinking just to be safe i should continue the ghettoness on the setup and weld a divorced wastegate into the exhaust mani (stovebolt style ) the intake is a standard 1800 intake with the turbo shooting right into the normall carb spot. i have yet to put a boost guage on it and see what it's putting out. but she spools nice until the plume of burnt oil comes out. Damn the l20b gets up in revs super quick with this (i'm being super carfull). im thinking about running the ignition without any vacume advance (at least till i figure out how to remap the curve) I'll slap up some pics tonight. Quote Link to comment
N0RCALDIME Posted April 20, 2009 Report Share Posted April 20, 2009 still need a wastegate? i think i have an extra. Quote Link to comment
Lozer Posted April 20, 2009 Author Report Share Posted April 20, 2009 hells yea! Quote Link to comment
N0RCALDIME Posted April 20, 2009 Report Share Posted April 20, 2009 you has a PM Quote Link to comment
Lozer Posted April 21, 2009 Author Report Share Posted April 21, 2009 Well i called just about everyone that deals with old ass corvair turbos and found out that no one on earth has a frickin oil seal (piston ring) for this pos. so i attempted to fabricate my own. It works marginally i only get a small cloud of smoke now. :mad: so on 2 phase 2 now i got an idea to turn this turbo into a small blower. im going to remove the exhaust turbine and housing and weld or thread on a stud so as to mount a pully :lol::lol::lol: needless to say i am less then happy at the moment and looking for alternative turbo's Quote Link to comment
Phlebmaster Posted April 22, 2009 Report Share Posted April 22, 2009 That thing is cool!! Quote Link to comment
Lozer Posted April 22, 2009 Author Report Share Posted April 22, 2009 ill sell it to you cheap! Quote Link to comment
sssr20det510 Posted April 22, 2009 Report Share Posted April 22, 2009 why is it backwards? can you flip it so the turbo points to the front Quote Link to comment
Lozer Posted April 22, 2009 Author Report Share Posted April 22, 2009 i probably could but the routing shoots the intake boost straight into the intake manifold like this. 2" piece of hose from turbo output to intake mani Quote Link to comment
sssr20det510 Posted April 22, 2009 Report Share Posted April 22, 2009 was thinking of your set up Turbo's and carburetors There are 2 ways in which a turbo can be set up with a turbocharger. Draw through and Blow through. With both set ups, the normal sized carb should be suitable. Draw through Far and away the easiest of the 2 to set up, however there can be issues with it, and its performance isn't as great. It, as the name suggests, draw air through the carburetor, to the turbo, which then compresses the air/fuel mixture. Cars, such as the Corvair and the turbo Trans Am had such a system. Benefits - You don't need any form of adjustment for the carburetor to adjust fuel flow - as the carburetor is on the "atmosphere" side of the turbo, and therefore the pressure it sees is the same, therefore it is much easier to set up. Detractors - Poorer performance - The turbo now has to draw a much heavier fuel/air mixture, and therefore it isn't as efficient. Since fuel is much denser than air, it can separate in the turbo, and pool, creating some turbo lag. The turbo can't be positioned right on the exhaust side, and it requires longer headers - which will cause further turbo lag. Also, given you are drawing air through the carburetor - which drops pressure, and then you are increasing the pressure with a turbo, means further inefficiency as you are compressing air from a lower pressure, and it will also increase your intake temp - and you can't run an intercooler (running fuel/air through one can be VERY dangerous (the fuel can condense inside the intercooler core and stay there if you then have an engine backfire the intercooler can explode), likewise a blow off valve shouldn't be used (it would eject a fuel/air mixture into the engine bay). Water Injection is the only way of cooling your intake charge. If you are building the engine in the backyard cheaply, this most likely would be the preferred way to go, as long as you can live with the turbo lag, and don't want to run obscene boost pressures. Blow through More complex than the draw through arrangement, but if set up correctly, has much improved performance. It, as the name suggests again, means that the turbo is mounted before the carburetor, and it blows air through it. To my knowledge this system has never been fitted to a production vehicle. Benefits Pretty much all of the detractors for the draw through set up are now reversed. You can use a blow off valve, an intercooler, turbo can be mounted on a set of real short exhaust headers, you aren't drawing air at a lower pressure etc. Detractors It is (as I mentioned previously) more difficult to set up. You have two major dilemma's: 1. A carburetor can monitor air speed, and adjust fuel flow accordingly, but it can't measure an increase in pressure. Therefore, you may have a system making 15psi, and sending double the amount of air that a N/A engine would receive, but the carburetor would only provide fuel for the N/A engine, meaning it will run super lean. As turbo's boost isn't linear, it can make it hard to tune. 2. You will now have a positive pressure, and it can cause headaches with your fuel flowing through your jets. The pressure will try to crush the fuel float, it's going to want to blow fuel mix out the throttle shaft, or back into the fuel line. Also the carb must be sealed so it does not leak the pressurised air-fuel mix - it would be extremely dangerous. The best method I have heard of is placing the carb in an air tight box, and running a sealed throttle cable. Because as the turbo increases boost that is more boost that the fuel pump must be able to overcome if it wants to push fuel into the carb. What you want is an electric fuel pump and a boost sensing fuel pressure regulator to increase fuel pressure as turbo boost pressure increases. Fuel floats should be filled with something so they don't get crushed under the pressure. For the black art of fuel enrichment (to adjust for the higher pressures that the carb can't monitor) I have heard some people overcome the first issue by just jetting the carburetor for when it is at maximum boost, however, when the turbo isn't at maximum boost (the majority or the time for a street driven vehicle) it will run horribly rich, and isn't really a suitable solution. Another, better method is to have 4bbl carbs, the secondaries are jetted for the higher air pressures, and are operated by a vacuum system to open under sufficient turbo boost. There are other more advanced methods, but if you want to attempt them, you (in my opinion) might as well run a basic EFI system, as most of them just attempt to mimic an EFI system. So, what have you learned after all this. Run EFI!!! Quote Link to comment
N0RCALDIME Posted April 27, 2009 Report Share Posted April 27, 2009 TBI is also an easy alternative. The TBI system injects fuel at the throttle body (the same location where a carburetor introduced fuel). The induction mixture passes through the intake runners like a carburetor system, and is thus labelled a "wet manifold system". Many of the carburetor's supporting components could be reused such as the air cleaner, intake manifold, and fuel line routing. Making is also a cheaper alternative. I'm more familiar with TBI than anything. Quote Link to comment
610SSS Posted April 27, 2009 Report Share Posted April 27, 2009 WTF:eek: U need a old school nissan t3 turbo, something like a fj20 turbo, u need to have carbon seals for draw thru coz of the fuel going into the turbo. If u flip the turbo so its facing the front, U can run a pipe from the turbo to the manifold like mine:cool: LIKE THIS(ʍoןǝq) Quote Link to comment
N0RCALDIME Posted April 27, 2009 Report Share Posted April 27, 2009 FTW?! thats sick! Quote Link to comment
610SSS Posted April 28, 2009 Report Share Posted April 28, 2009 LoL its sh*t atm:blink: Quote Link to comment
