Wanted L16 distributor base
  • Replies 5
put motor on TDC so the oil drive is hopefully in the 11:28 position
now you migh be able to rig this to work by flipping the timming plate and using a MINI C clamp to hold the dizzy so it dont move. Just to get it to work
or just get a L16 mount. I have mounts but dont want to part w/them as I have 2 new spare SSS dizzys
The L20 pint can be converted to a Pertronix if you cut the Ring above the point lobes.
Or the SSS is just s drop in
Pertronix you use the stock coil and Ballast resisitor or equiv OHM wise so not to Pop the Pertronix as its a eleltronic trigger more than a true 12volt EI ignition.
HI I am in need of the distributor base I have a new SSS distributor and the L20B base bolt down is on the worng side and the hole is out of alinement please any help thanks
post a pic of your wrong one.
I may have the one you need.
shit I tryed to post photos I cant get it to work ,but yes the L20B base will work if I redrill the hole and tap but it looks like shit .Iam doing the polish aluminum look on the front of my motor and thats the only part mismatched I hate to polish that one my fingers cant take much more buffing
