Rubberman Posted March 28, 2009 Report Share Posted March 28, 2009 I'm needing a water pump pulley for my new motor. It has the 4 bolt mount without the fan clutch. Can find anything in the yards around here. Here's some pics of the motor, hopefully you can see from the pics what I'm needing. Thanks Link to comment
jovial_cynic Posted March 28, 2009 Report Share Posted March 28, 2009 I've got a few spares. Where abouts are you located? Link to comment
Rubberman Posted March 28, 2009 Author Report Share Posted March 28, 2009 I've got a few spares. Where abouts are you located? I'm in Tenn. 37663, forgot to add that. Link to comment
djlotus Posted March 28, 2009 Report Share Posted March 28, 2009 I may have one floating about Link to comment
jovial_cynic Posted March 28, 2009 Report Share Posted March 28, 2009 I'm in Tenn. 37663, forgot to add that. $20 and it's yours. Link to comment
Rubberman Posted March 28, 2009 Author Report Share Posted March 28, 2009 Thanks for the reply djlotus. Jovial cynic, I sent you a pm. Link to comment
MikeRL411 Posted March 31, 2009 Report Share Posted March 31, 2009 Most any Ford V8 or Chevy big block water pump pulley [with appropriate slot filing of the bolt holes to accomodate the Datsun metric spacing] should work. They are usually two belt units and one will normally line up. In the worst case you might need to shim between the pulley and water pump to align the belt. Early Datsuns had two piece fans with a spacer which is about the thickness needed to align the Ford pulley. Link to comment
Rubberman Posted April 3, 2009 Author Report Share Posted April 3, 2009 $20 and it's yours. jovial, got the pulley today. Thanks again Link to comment
