datsunfish Posted March 23, 2009 Report Share Posted March 23, 2009 What strut inserts would work for a 3-4" drop. Its a 71 and the strut towere are rediculously tall. Super lame. I can fit my head between the tire and fender..:D Quote Link to comment
freaky510 Posted March 23, 2009 Report Share Posted March 23, 2009 (edited) are they stock or 280zx struts the 280 will give about 1.5 drop i believe also i have heard of people using a rabbit insert do a search on mkltoz post he did a strut right up that might help edit i found it http://forum.ratsun.net/showthread.php?t=6895 hope this helps Edited March 23, 2009 by freaky510 i searched lol Quote Link to comment
thisismatt Posted March 23, 2009 Report Share Posted March 23, 2009 Strut (or shock) towers are what are formed into your wheel wells. Strut tube is what you want to shorten. Quote Link to comment
Icehouse Posted March 23, 2009 Report Share Posted March 23, 2009 I thought he meant lower spring perch on strut tube :D I've used zx and VW inserts, I prefer the VW ones. If your going to use stock spring perch and isolator I would recommend the VW inserts. I have zx length ones in my car and if I have to much weight in the car they bottom out. Which has a little to do with spring rate (ST springs) and that there isn't much suspension travel left even with the shorter inserts. Quote Link to comment
