In need of.....
can someone help me out? My automatic tranny in my truck is about to done for and don't wanna be left stranded somewhere. I have a 4spd thats going to replace the tired 3spd and am in desperate need of a Flywheel, Clutch Fork, or T/O bearing collar.
thanks
  • Replies 39
thanks
I have a 5 bolt flywheel thats yours if you want it. I'm over in Ilwaco. Do you have the pedal set already? Pilot bushing?
I need a 6 bolt one. not sure on the mm...
I might have the fork and collar up in storage, almost positive just gotta check to be %100 sure.
and the flywheel I have is a 6 bolt.
Edited by Skib
I got one. Free... In LOS Angeles though...
yeah kinda far....
Do you know the mm on the flywheel? so I can ask around. What would you want for it?
yeah kinda far....
its a stock N/A L6 flywheel, Ill find the mm on it
edit: should be 225mm
Edited by Skib
From another thread...
The l20 is a 6 bolt crank and most L20s arw from trucks and run a 225 mm flywheel .
you can come grab it tomorrow if you want it man, if you want to see if I have the other stuff (Im almost positive I do) we might be able to roll out to where my parts pile is and check for them.
