Info on carbed KA24e
airedout
  • Replies 6
I believe you have to either make a manifold from KA and cut off the runners and make new runners and use the mounting plates from a carb manifold and of course your carbs you want to use. you will have to make a cable pull for the throttle. you will also have to use a electric fuel pump. I believe Nissan motorsports may still sell a manifold or some guys around do make one.
