kf6rcp Posted March 10, 2009 Report Share Posted March 10, 2009 I would like to ask anyone around that if with engine off take the dist cap off and try to rotate the rotor counter clockwise it turns like .5 in then release it and it comes back. Is this normal? Any inputs will be great. Also, if this is not normal what will be the problem? How is it linked to the gears? I know it is hooked up to the oil pump. Quote Link to comment
datzenmike Posted March 10, 2009 Report Share Posted March 10, 2009 Sure you aren't turning clockwise? Quote Link to comment
kf6rcp Posted March 10, 2009 Author Report Share Posted March 10, 2009 nope, when i turn it clockwise it just moves tiny but when I go couter clockwise it moves/turn like .5 inches and when I take my had out it springs back to the original position. Will this be causing my problem when I speed up to like 3rd or 4th gear it starts to back fire and stalls then when I park it on the side and restart it it starts? Quote Link to comment
banzai510(hainz) Posted March 11, 2009 Report Share Posted March 11, 2009 (edited) Dazenmike you know????????? I forgot if it moves that much I have to go home and see if it can move that much. KF6rcp, Ill ck I might be wrong on this one. Im not positive if it can move that much. For the mechanical advance. I know the weights cam move a 1/4 inchin for sure in the rotor slots. UPdate, More I think about!!!!! But it does make sense it can move Couter clock wise more as that would be advanced(mechaical operation). IM thinking its more MSD proplem/coil or carb. Edited March 11, 2009 by banzai510(hainz) Quote Link to comment
banzai510(hainz) Posted March 12, 2009 Report Share Posted March 12, 2009 I cked and YES it can move qnout 1/2 inch Couter clock wise if you force it. I bet your dizzy is fine Quote Link to comment
Phlebmaster Posted March 12, 2009 Report Share Posted March 12, 2009 nope, when i turn it clockwise it just moves tiny but when I go couter clockwise it moves/turn like .5 inches and when I take my had out it springs back to the original position. Will this be causing my problem when I speed up to like 3rd or 4th gear it starts to back fire and stalls then when I park it on the side and restart it it starts? Do you have a dual points distributor? If so, then you might need to look at your retarded points and make sure it is gapped and set right. And it is normal for your rotor to do that. lol Quote Link to comment
kf6rcp Posted March 13, 2009 Author Report Share Posted March 13, 2009 Thanks Karate kid for checking on the distributor. Quote Link to comment
kf6rcp Posted March 13, 2009 Author Report Share Posted March 13, 2009 Aaron, thanks also for the verification on the distributor. I have a 1978 dizzy with a pick up coil. Its not contact points. Quote Link to comment
datzenmike Posted March 13, 2009 Report Share Posted March 13, 2009 (edited) If a true '78 it's not likely a 'matchbox' type, but a remote igniter with a separate box usually mounted under the dash. And YES I miss read the OP you did say counter clockwise. My oops. :D Edited March 13, 2009 by datzenmike Quote Link to comment
