SRSANDS Posted March 4, 2009 Report Share Posted March 4, 2009 OK I have a questions about offset. I am using the zx front struts in my dime so what offset choices will work? The rear of course is stock so zero offset is ideally needed. I would like to get some deep dish wheels eventually so it seems I would need a negative offset wheel. What in your guys experience will work? Whats the highest offset and lowest neg offset that has been used? Using the front zx strut changes my offset option up front so can I use a front and rear offset combo? Its hard to order or purchase rims just to try em on and they dont fit so I figured Id ask. I know positive offset 4x114.4 are very common and for sale everywhere.......let me know thanks Quote Link to comment
banzai510(hainz) Posted March 4, 2009 Report Share Posted March 4, 2009 (edited) Im Positive 15x6 Panasports with +22mm fit on a LOWERED 510 EZ. The rest is a match/math question!!!!!!!!! Edited March 4, 2009 by banzai510(hainz) Quote Link to comment
LeX Posted March 4, 2009 Report Share Posted March 4, 2009 15x6.5 +13 fits great on front Quote Link to comment
Duke Posted March 4, 2009 Report Share Posted March 4, 2009 I have 15x7 zero offset with 205-50-15's all around. When I first put them on my suspension setup was 280zx struts with camber plates up front and an unmodified x-member in the rear. The wheels kinda fit. The front fenders were rolled and the rear ones were rolled and the inner fender well persuaded with a hammer. Even with this I still had a bit of a rubbing issue in the front. However, my car was really low as well (tucking tire). If it was a little higher, and you used some 195's, they would have fit pretty easily. Quote Link to comment
LeX Posted March 4, 2009 Report Share Posted March 4, 2009 I have 15x7 zero offset with 205-50-15's all around. When I first put them on my suspension setup was 280zx struts with camber plates up front and an unmodified x-member in the rear. The wheels kinda fit. The front fenders were rolled and the rear ones were rolled and the inner fender well persuaded with a hammer. Even with this I still had a bit of a rubbing issue in the front. However, my car was really low as well (tucking tire). If it was a little higher, and you used some 195's, they would have fit pretty easily. with a 15x7 +0(3) on the rear and rolled fenders, any thoughts what the widest tire I could run are? At least with absense of any wheelgap if not dumped (on a wagon so no camber issues in the rear) Quote Link to comment
Duke Posted March 4, 2009 Report Share Posted March 4, 2009 with a 15x7 +0(3) on the rear and rolled fenders, any thoughts what the widest tire I could run are? At least with absense of any wheelgap if not dumped (on a wagon so no camber issues in the rear) Goon's are a bit tough. With my car the camber gain with the IRS helps with clearance. With a solid rear axel, you don't get that. I would say that 195's would be the most you could run without having rubbing issues. I'm no expert though, as I have never messed around with a goon. You would need to roll the fenders for sure though. I know that there are a few people out there running 16x8 zero offset on wagons, but I can't attest to how well they fit. Quote Link to comment
Cuts metal like mad Posted March 4, 2009 Report Share Posted March 4, 2009 I have 15x7 +15, they will not fit my 280zx struts without a MINIMUM 3/8" spacer, and even with that, theres a business card worth of clearance with the strut tube. Quote Link to comment
banzai510(hainz) Posted March 4, 2009 Report Share Posted March 4, 2009 280ZX Front Strut and Brake Setup Custom Rear Disc Brake Conversion Stainless Steel Brake Lines Custom Line-lock -----Wheels----- Rota RB 16x7 +25 Offset Falken Azenis RT615 205/40/16 http://orangecounty.craigslist.org/cto/1057659331.html Quote Link to comment
SRSANDS Posted March 5, 2009 Author Report Share Posted March 5, 2009 Thanks guys......anyone else wanna put their input lemme know.... Quote Link to comment
bucket Posted March 30, 2009 Report Share Posted March 30, 2009 i got a goon w/ 280zx stuts and i belive 12mm offset is what ill need on the front but the 23mm offset fit the back. ( i got to try on one of hainz rotas) so far this is what ive found out, but still need more info. Quote Link to comment
Cuts metal like mad Posted March 30, 2009 Report Share Posted March 30, 2009 ok heres a little math to help out... 3/8" is equal to approx 9.5mm (we'll call it 10mm)... my +15mm wheels minus the 10mm spacer makes a +5mm wheel (15x7) and BARELY fits the 280zx strut... (giving you the option to run from a 0et to a +5, spacers included) I'd rather have an extra 5mm clearance, and +0 15x7 wheels are easy enough to find, so if you want 15x7s get a 0et wheel. 6.5" wide wheels open this up a little more... you only gain approx 6mm more clearance, but every bit helps, what this means is that on a 280zx strut, you can go anywhere from -6mm to a +11mm (this is theory, in reality different wheels fit slightly different and not all manufacturers measure their wheels correctly...). The 6.5" wheel gives you better options in my opinion, more strut clearance means you can go lower... and shawn I know you feel me here :D I'd say if you can somehow find a 6.5" wheel in 0 offset you'd be PERFECT on the ZX strut... Happy datsuning... Quote Link to comment
