kaoss Posted March 3, 2009 Report Share Posted March 3, 2009 Ca18det, ka24e, l20b These are what I am considering for my 77 620 project. It is going to lay flat rocker, so hood clearance is an issue. Here is what I have come up with and would like to know what you guys think. I Quote Link to comment
sanitys Posted March 4, 2009 Report Share Posted March 4, 2009 Ca18det, ka24e, l20b These are what I am considering for my 77 620 project. It is going to lay flat rocker, so hood clearance is an issue. Here is what I have come up with and would like to know what you guys think. I Quote Link to comment
mike Posted March 4, 2009 Report Share Posted March 4, 2009 VG30??? theres some pics of a couple 510 swaps from canby that were super clean. They are wider but youd have hood clearance. Ditch the torsion bars and youve got all the room in the world. VG30ET or DETT would probably be double the headache but youd probably rape just about anything as soon as you got traction... Quote Link to comment
motavated Posted March 4, 2009 Report Share Posted March 4, 2009 I got smoked badly while racing a sr20 sentra. I have a l20b so think about that. So if you want hp... L20b is weak... Quote Link to comment
kaoss Posted March 4, 2009 Author Report Share Posted March 4, 2009 So the VG30 is shorter than all listed? I'll spend some time researching the VG30. The torsions are going since I am bagging it. Quote Link to comment
BEEBANI Posted March 4, 2009 Report Share Posted March 4, 2009 Yes, I have at least 2-1/2" clearance on the hood. The ka sits very low and flat. Big plus. Other plus, several of us have done it; tried and true, I've beaten several hondas in my truck, aftermarket is pretty good for that motor. The ka sohc is damn near bullet proof and will almost never let you down. Not that I'm interested in loosing my reign as the only bagged, ka'd 620, but it's definitely the way you should go man.:D Quote Link to comment
kaoss Posted March 4, 2009 Author Report Share Posted March 4, 2009 You'll still be the only bagged KA'd 620. I'll be the only bagged and bodied KA'd 620 ;) Quote Link to comment
Bleach Posted March 4, 2009 Report Share Posted March 4, 2009 I got smoked by an '84 Sentra too. 350Z engines are crap... :( ;) Quote Link to comment
NorCalDime Posted March 4, 2009 Report Share Posted March 4, 2009 I wanted to go CA18 on my car at first, but then you have to think about all teh extra fab work you have to do to get it in. And the parts avaliability isnt the greatest in this area, gotta go out of auzzy land. I just recently put a ka24e in my dime and it runs circles around my old l20 and it was worked over pretty good. Quote Link to comment
LeX Posted March 4, 2009 Report Share Posted March 4, 2009 you can find a CA18ET for cheap.... S12 guys swap to the DET or SR and get rid of them cheap.. prob a bunch of fab work again but the motor itself is inexpensive maybe you would find one on club-s12.org They are around 135hp 145tq stock. Upgrade the turbo to a T25 from an SR and put on a downpipe and other junk and a perfectly quick little engine Quote Link to comment
philip1 Posted March 4, 2009 Report Share Posted March 4, 2009 the sx guys also swap in the RB 20-26 det engines I wonder if one of those would fit that would be so cool. Quote Link to comment
b210in Posted March 4, 2009 Report Share Posted March 4, 2009 (edited) i would shoot for the ka24e, specially if you already have one. keep in mind to that having just the engine and trying to piece everything together like the ecu, sensors and harness will "20buck" you to death. it 's cheaper to find a complete low mileage engine set. just for your info, in case you are interested, my dad just crashed his nissan truck with 85 thousand original miles, i will be taking the entire engine tranny and harness along with everything else and selling it. i'm doing a ca18det swap right now to my b210 and it's really not that complicated of a swap. it would probably be easier in your truck since you have more space, the only draw back to swapping this engine in your truck is that it lacks a lot of low end torque. Edited March 4, 2009 by b210in Quote Link to comment
kaoss Posted March 4, 2009 Author Report Share Posted March 4, 2009 I think that I am going to go with the KA24e. Beebani's engine compartment is pretty clean. The only reason I want the car intake is hood clearance. I wouldn't have to get it rebuilt until it told me that it needed it. It would be the cheapest route for me, without a rebuild. Thanks for the input guys, this has been a great discussion :) Quote Link to comment
LeX Posted March 4, 2009 Report Share Posted March 4, 2009 I think that I am going to go with the KA24e. Beebani's engine compartment is pretty clean. The only reason I want the car intake is hood clearance. I wouldn't have to get it rebuilt until it told me that it needed it. It would be the cheapest route for me, without a rebuild. Thanks for the input guys, this has been a great discussion :) and down the road its easy to do a cheap turbo setup on a ka24e :) T25 + FMU + 6-8lbs boost for safe easy cheap turbo setup if it's not fast enough ;) Quote Link to comment
kaoss Posted March 4, 2009 Author Report Share Posted March 4, 2009 true about the turbo, but then there is that little issue with traction... So I did some more reading, and do I need to get the oil pan from a 240sx also? What about the oil pickup? Quote Link to comment
Bleach Posted March 4, 2009 Report Share Posted March 4, 2009 what you want is rear sump, so if its a Hardbody truck engine then you're set! Just add the 240SX intake manifold and some injection. Quote Link to comment
kaoss Posted March 4, 2009 Author Report Share Posted March 4, 2009 sweet. I've read so much that I have a face ache! The only thing that I didn't find info on is the drive shaft. I would prefer to use the tranny that is already on the KA. I have the set up for a 4 speed, and I may have the set up for a 5 speed, (and yes i may have a 5 speed, so chill) on the 77's, but I don't know if there is any differences between the two:blink:. I guess it wouldn't cost to much to have a drive shaft shop make me one that ran from the tranny to the carrier bearring. Quote Link to comment
