Z24 dizzy
hang_510
anybody have one for sale?
i was ready to fire mine up and didnt have any spark (likely the MSD box)
when i pulled the rotor off i noticed 1 of the edges (on the 4 point part that the rotor sits and triggers the spark) was missing a small cresent shaped piece, probabaly from hitting something.
with it partially broken, will it still trigger properly???
  • Replies 6
Brian the Z24 dizzy has 8 plug wires and fires two coils. Did you modify yours? I have a spare Z20E matchbox dizzy for a Canadian four plug motor. Looks just like an L20B but the #1 position is 180 out.
:confused: whats in there ???
ill get a pic over the weekend so you can ID it. :D
its larger than the 200sx e-dizzy.
it has everything internal, 4 wires. the magnetic p/u is angled inside
the broken star is the only reason id need to replace it.
gotta get the spark from the MSD working and it should run.
^LOL
it was already installed in the car when i bought it, its at least 15 YO, "running when parked" :rolleyes:
i have someone who will loan (then sell) a spare box if it turns out to be the prob.
what are you suggesting i replace it with?
Factory EI dizzy... you can't beat them with a stick. Takes a lickin' and keeps on tickin'.
Refresh my old memory, Brian... you got an LZ22 motor with an L timing cover?
Yes, take pictures, lots of them. See you Mon.
:eek: apparently it will!
its running now!
1 broken wire from the MSD box fixed and it fired on the second crank :D
this is on the LZ24 (not the LZ22) the dizzy has no markings on the outside of it.
it looks to be a 'stock' magnetic trigger inside...
