paradoxx Posted March 3, 2009 Report Share Posted March 3, 2009 (edited) Hi everyone, Ive been having some problems with my alternator. Some people here told me that the alternator from a nissan B11 will fit on the motor mount. Do you have any clue if this is for real? If it is, how is the wiring procedure to amke it work? Or what other alternator will work for me. Thx in advance! Edited March 3, 2009 by paradoxx Quote Link to comment
Pacific coast Datsun Posted March 3, 2009 Report Share Posted March 3, 2009 I used an alternator meant for a 1981 510. They are a 60 amp output. A bit of an upgrade from the stock 35 amps. It bolted right to the stock mount. & the new 60 amp unit is internally regulated which means you can remove the voltage regulator. There are 2 wires you cut off the plug that goes to the VR & they get spliced into the "T" plug on the back of the new alternator. I know Hainz & Datzenmike have that diagram showing which 2 wires to cut/splice. Quote Link to comment
banzai510(hainz) Posted March 3, 2009 Report Share Posted March 3, 2009 (edited) http://datsun510.com/photopost/showphoto.php?photo=124&size=big&papass=&sort=1 no need to cut wires.This is a datsun 620 version,On left as it uses a Round connector for the Volt reg just make jumpers at the voltreg connector the one to the right should be a 510 type connetor and needs 2 jumpers. Use the color code TO Engine as I have seen some aftermarket Volt Reg colors to be INCORRECT!. I heard KA motors use a V belt pulley. I dont know About if they still use a T connector or not PS Not my photos Edited March 3, 2009 by banzai510(hainz) Quote Link to comment
paradoxx Posted March 3, 2009 Author Report Share Posted March 3, 2009 Thank you both for your answers.......let me check this week for a lil bit of time for installation. Quote Link to comment
Pacific coast Datsun Posted March 4, 2009 Report Share Posted March 4, 2009 TY hainz & sorry paradoxx. I forgot to mention that i did the swap on my 74 620. The wiring harness's are different [colors] Quote Link to comment
