Hey, so recently i rebuilt my L18 (thanks to this community) and now i have fuel dumping into the oil pan. Let me tell you what ive done so far
1. I adjusted the weber three times with three different people who claimed they know webers. My friend who did it last has actual had results and the carb is leaner but still dumping some fuel in the pan.
2. I have changed the oil plenty of times 4 times so far, the engine has 110 miles on in since the rebuild. I dropped the pan also just to change the gasket and also precaution to see whats going on down there.
3. I have driven it a lot to get the crank as hot as the thermostat can get, 180 degrees. Usually i sit around 160 while driving, idle will get it to 180 and a little over.
4. I did a leak down test and the engine has no leaks. It almost matches perfectly with psi i am testing with. 70psi. I was told not to go over that.
I know the next step would probably be re jetting the weber. However, I have no freaking clue how to do that or even select the correct size jets. Please help i dont want to ruin my engine.
