83 -
Florida
1977 280Z, 1956 F100, 1973 620, 1977 Monza
Cars....
2,624 profile views
Volition73's Achievements
I'm in the middle of piecing together my front brake system and I have seen a few threads/videos that mention this but here's where I am: I have the Hub/Spindle/Brake parts from a 1995 4cyl 2wd Nissan D21 - these are single piston calipers I'm trying to verify that the V6 2wd dual piston calipers and mounting brackets from D21/Pathfinders will bolt directly to the above mentioned configuration without the need of the spindle/hubs from these. I can't get a definite yes from what I've seen online and I thought I'd ask before I just order the parts and hope for the best...Thanks! Vol
Pressure washer did...not much lol (did destroy a hidden rat nest though...) and she is almost bare... Next I'll make sure she's square and start to mock up the suspension
EDM620 I am thankful for that! I was considering reinforcing the setup I'm going to run but that is mostly for traction concerns...
EDM620 Yeah I figured I would just hit it with the pressure washer and wire wheel where I need to weld the suspension bits up and then get it all blasted and seal it up with POR 15...I'll check it over as well as I can, the frame seems way better off than my cab dammit...
EDM620 well heck that might be a good idea, there are a few places down the road from me, worth a shot...thanks!
Finally! Huge step forward...We have lift off! 47 years of grime should come off easy right? Tomorrow I'll hit it with some degreaser and the pressure washer...
Back at it... Got the steering assembly out and managed to get all of the cab mounts out too. Tomorrow I'll start making a dolly to make it easier to move the cab around. I'll get to work on mocking up the frame for all of the suspension components and while I wait for parts (and funds lol) to get the suspension done I'll start in on the surgery...I'd appreciate any tips or similar repairs in the following pictures...Hope everyone is well as this covid situation continues... The windshield is the area I'm most worried about... Both hood hinges are shot... Glad I was able to get some new ones...
Got more done today, took 3 engines to the machine shop, picked up some metal (think I got enough?) and dropped the 620's old eng/trans to a fellow datsun guy. Got the dash out today and got a hold of a local fabricator who will help some metal stuff I can't do (run some beads on my soon to be floor pans and I'm gonna cut my cab mounts out and have him make some replicas I can just weld in with my new pans...)
http://paintref.com/cgi-bin/colorcodedisplaym.cgi?ditzler=44432
Hello, I'm trying to get a batch of Kelly Green for my 620...this link may help? http://paintref.com/cgi-bin/colorcode_mobilebutts.cgi?year=1973&manuf=Nissan&make=Datsun&model=Datsun&color=Kelly Green&code=940&wtcode=&gmcode=&dtcode=&ditzler=44432&dupont=31019&acme=90835&arco=&rm=&martin=&williams=4342 Let me know where you get it if you do, I need to order some as well...
$120 shipped, they seem decent and came with the rubber buttons, granted they won't do anything for a crash but I like the look and hopefully it'll keep me front a ticket if a cop knows I wasn't running a bumper without these.. I appreciate the info, I have everything for the brakes, I just need to sort out the rotor situation. Can he make custom rotors?
Overnight parts from Thailand! (I ordered these 3 days ago and was told to expect them between 30-70 days..I'm impressed!) Gotta love the extras in the box! Got the L28 tore down, looks ok to my eye...let's see what the machinist says..
Work took a huge chunk of time away but I'm back at it...Got the engine/trans out and bed off..I'll get the cab off in a few days...Been cleaning the engine bay and tore down a spare L28 block taking up some much needed floor space. I'll take that and the KA to the machine shop with some other parts to get cleaned up. A buddy is working on an MR2 and ordered a black top engine (hella JDM) and we're taking that as well. Once the cab is off I'll start in on the frame and suspension... I'm kinda stuck on two items, so if you wanna weigh in I'd appreciate some insight... First, are the rear brakes...I could use the stock Ford 8.8 disk/drum setup, but I'm having trouble sourcing a rotor to fit and be 6x5.5 lug patter..I seen this on another forum but I'm not sure I want this option... The other option is I get a kit from WilWood and with that kit I'll have to drill my rotors to match since they will be blank...I'm ok with this option if I can't find an easy OEM rotor for the other option... The next issue is the gearing for the rear end and the LSD type...I've been looking into clutch types since they can be swapped out and "tuned" so to speak, the idea for the truck is to be streetable but be decent in autocross and other events if I have the chance to make a meet. I"m not concerned with high speed or really stretching the engine out to high end. I picked the KA for it's low end torque and I'd like to keep it in the realm of fast acceleration vs high top speed. I'm not sure I'd wanna go above 120 in it anyway lol...So if you can speak to gear ratios and wheel size I'd like some pointers..I'd even swap the 18in titan rims out for some custom wheels if it meant a better setup. This thing has kinda developed into more than just a KA swap and I'd like to do it as "right"as I can. I'll have a few things I won't need from the original 620 stuff, smaller parts here and there..Like some electrical, drive shaft, wheels, spare tire/rim...Stuff like that so if you are looking for that let me know, otherwise I'll put it up for sale when it's all gathered up... Hope everyone is doing well during this covid crap
Been a bit as usual, but here is the latest... I got a shop in Kissimme FL to address the axle issues...I took the 620's axle and the 8.8 housing I sourced to them (pretty long drive that I'm glad I'm done with) so I couldn't mess up the measurements. They narrowed the 8.8 to match the 620's stock setup, slapped some late big ford flanges on (which eliminates the C clip issue with the 8.8), ordered and assembled 31 spline Strange Axles for me that are drilled to match the 6 lug pattern and fabricated all of the odds and ends I got to tie the Watts kit together. Now I'll just need to get the differential ordered and I'll have a local shop install it since I don't want to mess that up either. I'm working on finding a dual caliper setup so I can plumb a standalone hydraulic hand brake in. If you are in the area or want to deal with shipping, which they can do, I highly recommend TRZ Motorsports. The owner took a bunch of time going over my build and plans and honestly took my box of issues and turned it into a nearly bolt in solution. He had the guys there weld the custom top/center mount they fabricated onto the axle housing (I didn't think that was possible with the different metal types but they were able to) and even adapted the entire kit I got to fit the 8.8 axle. I'll even be able to service the differential with the way they adapted the rear cage (it's removable). All in all I'm blown away and I cannot wait to get this installed. Next is to get it all installed and have the drive shaft made which a local shop is going to do..thankfully they aren't several hours away this time. Pics below...
