36 -
Not Telling
New Zealand
'79 Datsun 620 '75 Datsun 620 '91 Nissan 300zx '94 Toyota Hilux Surf
Datsuns, music, guitar, drums
2,509 profile views
82m's Achievements
13
After a bit of research i have found that the US B210 A14s use a mid mounted oil sump, compared to the rest of the worlds front sumps.. I need a us style oil pan to fit my A15 into my 620. I can still order the pan ex Nissan Japan, but not the pick up tube.. 1. does anyone know of any reason why the mid sump pan wont work on the A15? 2. does anyone know if this is the correct pickup tube to suit the mid sump oil pan? https://www.ebay.com/itm/Sealed-Power-224-14181-Oil-Pump-Pickup-Tube-For-1975-1982-Datsun-1-4L/183555911349?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D0363fd25bb2948d8b88a1b52c7406b59%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D183555911349%26itm%3D183555911349&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A24590592-8beb-11e9-bc45-74dbd1806c6f|parentrq%3A4439c63016b0a9cc0714c1efffeb529a|iid%3A1 Thanks
So it's been a long while and after having to move hose a couple of times, shitty landlords and starting a new job, I've finally got around to doing more work on my Datsun.. A few pics of my front disc conversion As I said before, these are just spindles, hubs, rotors and calipers from a D21 Nissan Navara. I found that after repainting my wheels from the grey colour to gold the grey paint underneath would chip away really easily.. this wasn't so much of a problem, just annoying. What was the problem, I was told to just run RTV silicone to seal the center of the wheels, which didn't do shit.. So i took the back apart and had the centers sandblasted and I repainted them, With a bit of a different colour.. This was a couple of months ago. I used black silicone adhesive sealer, I think it was a CRC brand and seems to have worked great. I wasn't happy with how the engine was sitting in the engine bay so i rebuilt the mounts and i'm a bit happier with how its sitting, not the prettiest of things though.. After that was sorted I got a new set of extractors as the old ones had no hope in hell of clearing the torsion bars. I'm not 100 percent happy with the quality and look and still had to modify the new ones to clear. Ive basically made the complete new exhaust system, just dont have any photos I got a pair of Weber dcoe 40s and after rebuilding them ive started mocking them up on the bench. I drilled and tapped the holes in the head for the stock water lines in the manifold and plugged them with some little grub screws. The linkage kit i got for them was absolute rubbish so i have basically replaced all the components in it. Now where I'm at right now.. I have come to see why the previous owner was soo keen on getting rid of this. The paint job was beautiful and near flawless when I fist got it. It has now come to light that the was minimal prep work done.. rust bubbles coming through, like the wheels the paint chipps off is you breath on it too hard and worst of all I found this gem I have cut it out and started to patch it, but the weathe has been crap here so this is where its at There is lots more to do and lots more that i have done, I will post more when I get more pictures, but for now I will leave you with these
I just saw a shock at work yesterday, I didn't have time to measure it up unfortunately.. but im sure it was shorter than any other shock ive seen. it was from a little Isuzu truck. NKR66e Isuzu part number 8972535920 KYB part number 444261 If someone has the resources to look up the dimensions that may be an option..
they are pretty easy to come by here.. pull it apart and find out what's wrong with it first tho
Now, on to my 620.. I have always wanted a Datsun of my own and when I saw the 620 I knew it was going to be that. I have owned this for about two years. But moving house like 5 times and never having the room to work on it, progress has been slow. When I got it, the previous owner had stripped it, painted it and then lost motivation. Im not sure how long it was sitting as a bare shell but he was pretty keen to get rid of it. This is how I got it I removed the cab to repaint the chassis and mount my A15 (the one from my dads sunny) This is where progress staalled. Due to moving etc. But I was able to do a bit of work in it while it was in storage. I did the 720 4X4 rear leaf swap and added some two inch blocks. I also disc brake swapped the front. As it is a '79 with ball joint front end, it was easy to just swap in the spindles from a D21 Navara. I also painted and polished my wheels. So after all that and also building a new garage with my flatmate, this is how it sits Cheers for checking this out. I hope it satisfies your oic cravings there will be more to come
G'day guys, I've been lurking here for a while now. Decided its time for my own thread.. Ill start with a bit of back ground on myself; My love of Datsuns started when I was quite young, maybe 5 or 6. My Dad built a kit car for a friend. It was a Jaguar Swallow, looks like this; But it was powered by an L24 or an L26 (cant remember) with a cam and triple carbs etc.. but the sound of that was unreal. A while later, when I was twelve my Dad then made me a Ministock. These are a youth dirt track speedway class. They are powered by Datsun Sunny or Toyota Corrola 1200cc engines and running gear. You can guess which one I had. Here's a few photos of it; You can see where my screen name comes from haha My older brother then got a nice litte B310 Sunny coup. We rebuilt the engine and fixed the rust. It was a solid car for a couple of years until he rear ended a late model Audi and insurance wrote it off. Now in New Zealand once a car has been written off it is quite a task to get it back on the road. My brother couldn't be bothered getting it back to Warrant of Fittness standard. So my dad brought it off him and is slowly turning it into a race car Yes that is a VG30DE under there.. Progress is pretty slow with this one due to his work commitments, but ill update when things get done.
