Custom L6 intake with fuel rail and throttle body
, Indiana United States
Custom Datsun/Nissan L6 intake manifold with fuel rail and and BBK throttle body with TPS.
Built on a Cannon intake manifold this custom intake manifold should bolt to any L6 cylinder head . I ran this manifold on a N47 head with injector cut outs on the head with no issues - just need to use proper gasket . Mates up with early heads with no injector cut outs also .
Runners are 37mm at the head surface tapering up to 44mm at the manifold plenum .
BBK throttle body is 75mm . I used cable linkage mounted to black stand off bracket in the pic .
Injector bungs are for 14mm injectors . Custom fuel rail fitted with this manifold has 1/4 NPT threads at the ends with 5/16” nipples currently .
Manifold has 3 vacuum ports at the end and also PCV on the bottom of the plenum .
Cannon mounting flanges at head are standard thickness and do not require step washers .
My project is moving a different direction and selling off parts that I will no longer be using . No defects with this manifold . I smoothed welds and polished the top surfaces only since that’s all that’s visible .
There is heat wrap on runner on bottom sides to protect against heat . I had no issues and this manifold performed great.
asking 500$ plus shipping
PM or
sfinnerty1018@gmail.com
Other adverts from Madkaw
