1972 510 4-Door Shell (only) SOLD!
$1,200
Advertiser
- Type of Advert FOR SALE
- Item Condition USED
- Time Left 11 days and 8 hours -
- Quantity 1
- Price $1,200
1972 Datsun 510 4-Door body shell ONLY. There is no title. To be sold complete. I will not cut up or part out.
I will not make any trades other than for Datsun 510 parts I may need.
This car is primarily good for the body segments that remain. EVERYTHING else has been "harvested". What you see is what you would get.
Note: All suspension parts are removed. If you want this shell, you will need a trailer. I will assist in loading, but cannot deliver.
There is no evidence of a big smashup anywhere, so if you need sheet metal repair pieces, this could work.
The floor pans are solid: A few small areas have been patched and everything has been painted with primer.
The trunk area has rust and dents. The roof is straight. The hood is quite straight and in pretty good overall condition. The Trunk lid is straight and has a small (drilled) hole that could be patched. The door hinges are sketchy. The front core support has been removed. The front valance is on hand and could be repaired. The strut towers are both solid.
All door glass is in good condition and an extra LF door is included.
Windshield is cracked; rear glass is in good condition.
I will respond to interested parties in the order of inquiry. I will not waste time answering questions about things that are addressed in this posting. I will not be hosting "tire kickers" - there are no tires to kick.
If the posting is up, the shell is still available.
email responses are preferred: davecsellers@gmail.com
Thank you for your interest. Long Live Datsun!
Other adverts from BvtnDave
FOR SALE
Wanted: 510 2-Door window frame glass run guide (Plastic)
By BvtnDave
9 days and 21 hours
NO VALUE SPECIFIED - WANTED
- FOR SALE
WANTED
Wanted: PL 510 (4-door) LR Glass run channel with SS Cladding
By BvtnDave
22 hours and 26 minutes
NO VALUE SPECIFIED - FOR SALE
FOR SALE
PENDING EXPIRED Nissan D21 (Hardbody) Factory Tachometer and Clock: SOLD
By BvtnDave
NO VALUE SPECIFIED
