maximo Posted February 23, 2009 Report Share Posted February 23, 2009 What happens is I dont hook up the vacuum unit to the Vacuum advance port on a Weber?? Can I switch the fuel inlet on a Weber, if is not in the place where I need it?? Quote Link to comment
datzenmike Posted February 23, 2009 Report Share Posted February 23, 2009 You should add your location to your signature before Mr. Peters gets home from work. What happens is I dont hook up the vacuum unit to the Vacuum advance port on a Weber??Can I switch the fuel inlet on a Weber, if is not in the place where I need it?? Can I assume you are asking " What happens IF I don't..." Vacuum advance is used to properly ignite your fuel and air at a time before TDC so that when it reaches it's highest pressure after TDC, the piston is in a perfect position to use it. Without advance, it will fire at the 12 degree static advance position which is too late, the piston will travel well past its best position to use the combustion energy and it will be wasted. It will lack power at low speed, be harder to take off from a stop and will waste gas. I don't know if it CAN be switched to the other side, but by all means do so if you can. It looks a lot better with the fuel line coming in on the correct side. Quote Link to comment
maximo Posted February 23, 2009 Author Report Share Posted February 23, 2009 thanks, I learn something new everyday Quote Link to comment
Phlebmaster Posted February 23, 2009 Report Share Posted February 23, 2009 You should add your location to your signature before Mr. Peters gets home from work. :lol: :lol: Quote Link to comment
Phlebmaster Posted February 23, 2009 Report Share Posted February 23, 2009 He is home.....:eek: Quote Link to comment
ppeters914 Posted February 23, 2009 Report Share Posted February 23, 2009 You should add your location to your signature before Mr. Peters gets home from work. TOO LATE!!!! Like they say in the real estate biz... LOCATION! LOCATION! LOCATION! Oh, yeah....nice response Mister Mike. :thumbup: Quote Link to comment
datzenmike Posted February 23, 2009 Report Share Posted February 23, 2009 (edited) Oh, Did I get it wrong? Maybe I should have said: before he gets up???:lol: Edited February 23, 2009 by datzenmike Quote Link to comment
