Ricky116 Posted February 21, 2009 Report Share Posted February 21, 2009 Hoping to get some feedback. I have a 77kingcab 4speed that I purchased recently. Its sat for about 6 years I dont know any history but the prob. is this. I cant get the cluch to disengage.I trailered it home and got it running today: I started it in gear and drove it down the rode with the pedal depressed and trompped on the gas to try to get it to free up but nothing. so with the pedal all the way in it acts as it is out. What ya think?:) Quote Link to comment
Wharf Rat Posted February 21, 2009 Report Share Posted February 21, 2009 First see if the fork is moving at the slave clyinder, if it is and the pedal feels normal then try just what you did again and get agressive with it on and off the gas. I have had old MGs stick realy bad after not being run for years. Had to do this shake thing for a mile or so to get them to come out of it. Good luck Quote Link to comment
datzenmike Posted February 21, 2009 Report Share Posted February 21, 2009 Check the slave cylinder/clutch fork is moving. Look below passenger's feet on side of tranny. If not check the master cylinder, just left of brake booster, for fluid. If dry fill and loosen bleeder on slave and have someone push down and hold clutch, allow air and dirty fluid out then close bleeder and release clutch... repeat until all air is pumped out and clear fluid comes out. Quote Link to comment
Ricky116 Posted February 26, 2009 Author Report Share Posted February 26, 2009 Well a couple miles of stabbing the gas pedal and a bed full of railroad ties freed the cluch Yea:) Thanks for the advice.. Quote Link to comment
ppeters914 Posted February 26, 2009 Report Share Posted February 26, 2009 Excellent. You should still flush the clutch & brake systems since it was sitting for so long. Quote Link to comment
