stock04srt4 Posted January 19, 2009 Report Share Posted January 19, 2009 i have just bought a 79 kc and r having problems finding some parts for it. im looking for the inner door lock rods. they seem to be bent and will not alow the door to be locked or unlocked. i tryed the dealer and they cant get them. i live on the east coast and there arent alot of places on this side of the country that has datsun in the junk yards. if any one know of where i might call or look it would be much appreciated. Quote Link to comment
420n620 Posted January 19, 2009 Report Share Posted January 19, 2009 there is a plactic adjustment nut, did you try adjusting it. sometimes they are a bitch, try spraying some WD-40 or liquid lube on them..... Quote Link to comment
dat620 Posted January 19, 2009 Report Share Posted January 19, 2009 there are new old stock for sale on ebay, other than that try your local junk yards, get a couple sets as they r old and do wear out, if u take the whole assmy out of your dors u can lube them and straighten rods out..i have done this on my trucks and they r still working, just some basic maintainence..:) Quote Link to comment
BarryA Posted January 19, 2009 Report Share Posted January 19, 2009 would lock, but the action on it was very stiff. In working through the whole locking system, it turned out that everything was dry and binding up - was able to straighten out the rods up to the lock knobs without removing everything from inside the doors (did have to take the inner trim panels off). Shot a bit of WD40 on all the connecting points plus a very tiny bit into the lock cylinder from the key slot (usually not the best solution, but graphite wasn't working), and everything's now working very smoothly. Lock cylinder was a bit loose in the door, so I pulled off the retaining clip and bent a bit more tension into the arms while the door panel was off - it's tight now. One other thing you may want to do while you're in there. There should be a grommet around the hole in the door top that the lock button rod comes up through - if the grommet is gone, it'll cause a rattle, so you may want to replace both grommets while it's apart. Quote Link to comment
sanitys Posted January 19, 2009 Report Share Posted January 19, 2009 just a thought but on mine I noticed the door wont lock unless the door is closed all the way. Quote Link to comment
