kjz71521 Posted January 7, 2009 Report Share Posted January 7, 2009 I have a stock l16 motor in one of my 521 and I am having problems with it ingauging to go into gear. can you guys give me feedback to let me know whats going on. The motor is fine and sounds good but it wil not go into gear.:confused: Quote Link to comment
datzenmike Posted January 7, 2009 Report Share Posted January 7, 2009 Lift the hood and check the clutch master cylinder reservoir. Is the fluid level right? If empty you could re-fill it, but it's likely leaking at the slave cylinder and will just go dry again. Take a look at the slave... it's probably wet or dripping. Let me know. Quote Link to comment
datsunaholic Posted January 7, 2009 Report Share Posted January 7, 2009 Will it go into gear if the engine is off? If the answer is "no" then the transmission is broken, not entirely unusual for the 521 stock transmission to have linkage failure. If the answer is "yes", can you start the engine with the clutch pedal depressed and the shifter in gear? If the answer there is "no" then the answer is the clutch is stuck (rusted to the flywheel or the clutch disc has delaminated, I've had both happen) OR the clutch hydraulics aren't working. The latter could be a dry hydraulic sytem, air in the lines, a failed master or slave cyl, or a combination. If you can start the engine, in gear, with the clutch depressed, then drive around in first but can't shift back into gear with the engine running once you pop it out of gear then usually the clutch is dragging. I don't think the problem is one other possibility (bad synchros) because that usually only manifests when moving. Quote Link to comment
datzenmike Posted January 8, 2009 Report Share Posted January 8, 2009 auto trans? :lol: I like that Actually I don't think autos were available on the 521s Quote Link to comment
