Moisabamf Posted January 2, 2009 Report Share Posted January 2, 2009 in our 510 there is a red/green wire that is just stray, and it always stays hot, even when the switch is off and we have no idea where it goes. the wiring harness is from a 1968 510 from a 4 door with an automatic tranny Quote Link to comment
moparvwfreak Posted January 2, 2009 Report Share Posted January 2, 2009 hot lead for the neutral safety??? Quote Link to comment
Guest DatsuNoob Posted January 2, 2009 Report Share Posted January 2, 2009 Maybe a constant power wire for a radio or something? Quote Link to comment
Bugeye Posted January 2, 2009 Report Share Posted January 2, 2009 have you looked at the wiring diagram for that harness? Quote Link to comment
Moisabamf Posted January 2, 2009 Author Report Share Posted January 2, 2009 its freakin impossible to find! :mad: all the wiring diagrams are from 1970+ Quote Link to comment
datzenmike Posted January 2, 2009 Report Share Posted January 2, 2009 Mo are you sure it isn't Green with a narrower Red stripe? All Nissan two color wires are coded with the second color as a smaller stripe. Anyway, where is the wire located on the car? There are several things with power without the need for having the ignition switch to the ON position. Horn Brake lights Interior light Emergency 4 way flashers Headlights/running/marker Quote Link to comment
