slodat Posted December 27, 2008 Report Share Posted December 27, 2008 Matt over on the 510 realm offers CNC machined adapters to allow converting a 510 from the stock universal joint axles to CV joint axles. The adapters are designed to work with Type II VW CV shafts. Parts needed: Matt's adapters. (2) 1980-1990 Vanagan axles. 21.25-22.43 inches long. Must be this length for resize. I used EMPI p/n 90-6805. I got them at Discount Import Parts in Portland for $150. (24) M8x1.25 x 60mm socket head bolts. 14mm thin wall socket. I found an SK at Baxter's that fit. Snap ring pliers. The axles need to be shortened and resplined. Dutchman Motorsports in Portland did mine for $120. The service order for the shortening and re-spline: Once you have your shortened axles back, it is time to assemble the half shafts. Parts laid out on the table: Slide the boots on the axle. They are different. Small boot inside diameter on smaller end of shaft. Slide the CV joints on to the axle shaft. Install the washer. And the locking ring. This is where those pliers are necessary. Make sure the locking ring is in the groove in the axle shaft. Grease each CV joint, packing the grease into both sides of the joint. Use the whole pouch of grease for each joint. Quote Link to comment
slodat Posted December 28, 2008 Author Report Share Posted December 28, 2008 (edited) At this point, the axles are together. Remove the stock half shafts aka "dog bones". Install all four adapters on their corresponding flanges on the diff stub axles and axle shafts. The adapters are the same. Use the stock hard ware and install in the same way the half shafts were once installed. I found it much easier to install the inner (diff side) flanges with the stub shafts out of the diff. They are easy to remove with a 14mm socket. Be careful to keep that bolt clean. When reinstalling the stub shaft, don't over tighten the bolt. You can strip out the threads in the carrier if you over tighten. Bolt the CV axles into place using the cap head screws mentioned above. I used some never-seize on the threads because there is a steel bolt going into an aluminum flange. Push the remaining grease into the boots. Tighten, check everything for clearances and enjoy. Edited December 28, 2008 by slodat Quote Link to comment
Jesse C. Posted August 5, 2009 Report Share Posted August 5, 2009 Any measurements on the shafts? What size to cut them down to? Quote Link to comment
ohpyramids Posted November 17, 2009 Report Share Posted November 17, 2009 Jessee this thread is awesome! thanks! Quote Link to comment
nudime Posted November 19, 2009 Report Share Posted November 19, 2009 are these adapters still available? im looking for contact info on the seller Quote Link to comment
sssr20det510 Posted November 19, 2009 Report Share Posted November 19, 2009 http://www.the510realm.com/viewtopic.php?f=10&t=9347 Quote Link to comment
Jesse C. Posted December 3, 2009 Report Share Posted December 3, 2009 Jessee this thread is awesome! thanks! Dang! I guess I better pay more attention!! :D Thanks! Quote Link to comment
