kcobb454 Posted July 22 Author Report Share Posted July 22 Banzai I’d like to chat on the phone with you if possible. Quote Link to comment
banzai510(hainz) Posted July 22 Report Share Posted July 22 long as you go the 12volts going to the ballast then the down side to the +side coil and the HOT start to +side coil that is it. hot start is the wire that has 12v only in the SART position. -side coil goes to the dist tab. take coil center wire place near ground and should give a snapping sparking to the chassis. Quote Link to comment
banzai510(hainz) Posted July 24 Report Share Posted July 24 you can also get a test light pull the point wire off. then take the allergator end of the test light clamp it to the tab. then take the other pointy end and hook it up to the +side battery. when light is on points are closed. no light points open. then start the truck and see if it flashes ON/OFF if yes then the dist is most likely good. then ck the capcitor. Most newer Volt meters have a cap cker mode Quote Link to comment
banzai510(hainz) Posted July 28 Report Share Posted July 28 I had this happen to my 521 last couple times i drove it. seem like I lost gas or ignition for a second or so. then just thursday I had it just die on me. Pulled over then it statred up and drove home fine. I looked at my Pertronix and looked ok then for some reason I turned the cap over and the center Carbon post on the dist cap was pretty much FLUSH. Just worn down to nothing. Then after that I looked at my rotor and notice it was the smaller L16 rotor in a L20 dist cap. I have been running this for years. the gap must be 1/4 inch and it ran fine for years. maybe Pinged a bit more. I have a stack of the old Standard Motor Product Blue streak Copper contack dist caps. Hopefull this will last another 8yrs!!!!!!! 1 Quote Link to comment
Stoffregen Motorsports Posted July 29 Report Share Posted July 29 What's that old saying - I'd rather be lucky than good. 1 Quote Link to comment
kcobb454 Posted August 3 Author Report Share Posted August 3 Well after an absorbent amount of time and agonizing over what could be wrong with the truck, I was able to get with Hainz and go over all of the common causes of the symptoms. Hainz kept leaning back to possibly distrbutor related so, I pulled the distributor and gave it a thorough cleaning and replaced the new condenser with another new one and Bingo, we now have a sweet running machine again!! Thanks to everyone for chiming in with ideas, much appreciated! And special thanks to Hainz ✌️ 1 Quote Link to comment
Stoffregen Motorsports Posted August 4 Report Share Posted August 4 I read on another forum about issues with new condensors. Many of the new ones don't last and/or are junk right out of the box. Quote Link to comment
