nathan.is.an.idiot12312 Posted March 18 Report Share Posted March 18 just curious if theres anyone that makes an upgraded cam for these engines anymore. thanks Quote Link to comment
Crashtd420 Posted March 18 Report Share Posted March 18 (edited) Probably not gonna find new but companies can do a regrind.... I used this place for my L series... They were able to do the grind and with new springs, retainers and correct lash pads. http://schneidercams.com/nissan.aspx Edited March 18 by Crashtd420 Quote Link to comment
nathan.is.an.idiot12312 Posted March 20 Author Report Share Posted March 20 thanks could you explain exactly what cam grinding is thats something ive never heard of lol Quote Link to comment
nathan.is.an.idiot12312 Posted March 20 Author Report Share Posted March 20 Just now, nathan.is.an.idiot12312 said: thanks could you explain exactly what cam grinding is thats something ive never heard of lol or just give me a source that explains it pretty thouroghly Quote Link to comment
Crashtd420 Posted March 21 Report Share Posted March 21 14 hours ago, nathan.is.an.idiot12312 said: thanks could you explain exactly what cam grinding is thats something ive never heard of lol It's pretty basic.... They just grind a new profile into the existing cam to give you more lift or duration.... Usually it comes off the base circle... Which is why new lash pads are needed.... this keeps the valve train geometry correct.... Have a read here... https://www.jalopyjournal.com/forum/threads/cam-regrinding-why-the-pointy-lobes.1044120/ Quote Link to comment
datzenmike Posted March 21 Report Share Posted March 21 Don't worry about any lash pads on an A series, there are none. The small amount removed is easily accounted for on the push rod/rocker arm adjustment. Over head cam engines are different, no push rods. 1 Quote Link to comment
Crashtd420 Posted March 21 Report Share Posted March 21 20 minutes ago, datzenmike said: Don't worry about any lash pads on an A series, there are none. The small amount removed is easily accounted for on the push rod/rocker arm adjustment. Over head cam engines are different, no push rods. Good point.... forgot its a pushrod motor.... Quote Link to comment
