seannn Posted February 21 Report Share Posted February 21 Hey guys, I am back at trying to fix the old 720. So I got the lights working with the manual so I decided to work on the front suspension. It doesn't even have shocks at front lol so I decided to ask my dad about it and he told me that the arm would always tear the shock in half so he just decided to run it without front shocks. Any idea why? The t bar isn't to tensioned. I noticed this afternoon that it didn't have bump stops it was just the little steel plate that once had the bump stop and I went to the local car parts and they say they didn't have any for this particular car. Does anyone have an picture of how it is too so I could find one similar and adapt it to the car. Could the bumps stops be the problem why it tears the shocks? Thanks Quote Link to comment
datzenmike Posted February 21 Report Share Posted February 21 Put what vehicle and year you have in your profile, saves guessing or asking. 2wd? 4x4? Try putting the correct shock absorber on. It should have room to move and not touch anything. Post a picture of what you have, maybe something isn't right As for the bump stop just cut a piece of rubber tire and glue it on. 1 Quote Link to comment
Stoffregen Motorsports Posted February 21 Report Share Posted February 21 If the truck is lifted and the shocks are stock length, it can damage the shocks by over-extending them. In theory, it could tear the chock in half, but I've never seen this. Seems like there's something else going on here. Use rockauto for pics of parts. Quote Link to comment
seannn Posted February 21 Author Report Share Posted February 21 (edited) The upper arm always tore them my dad has tried using original size, longer shocks and even thinner shocks and it had the same outcome. It edge like part from the arm always Hit the shocks and in a day or 2 you would hear alot of noise due to the shocks torn in half. I had already added it to my profile but I'll repeat it, it's an Nissan datsun 720 4x4 from the year 1984. That's why I assumed that with the absence of the bump stops were the problem but thanks for the tire tip I have extra tires that are rlly bald and don't hold air so I have use for them now lol Edited February 21 by seannn I forgot to add a part 1 Quote Link to comment
datzenmike Posted February 21 Report Share Posted February 21 Bump stops usually are used to limit compression of the suspension, aren't they? Is so not having shocks would definitely cause the suspension to bottom out probably damaging and removing them. I'd say the lack of shocks caused the lack of bump stops. A picture of this set up... because normally there is more than enough room for the suspension to articulate and NOT hit the shocks. 2 Quote Link to comment
Stoffregen Motorsports Posted February 22 Report Share Posted February 22 Yeah, I'm still confused. Unless you are jumping the truck or otherwise maxing out the suspension in some other way, it would never tear off a shock. There has to be some other problem. Misalignment of suspension parts from a bad accident could be one possiblity. Quote Link to comment
