Chief John Posted February 13 Report Share Posted February 13 My 520 headlight relay only has 4 terminals and I'm not sure which wire goes to which terminal. I looked online but can't find a schematic for the guts of the relay. It is a Nissan 25238-B7911. I'll try to post a photo once I figure out how. Thanks John Quote Link to comment
datzenmike Posted February 13 Report Share Posted February 13 25238-B7911 is for 810 fuel pump relay and 280zx EGI relay. The 520 headlamp relay is 25230-89905 but the other could quite possibly work. First, what are the wire colors???? Quote Link to comment
Chief John Posted February 15 Author Report Share Posted February 15 Wire colors Red/yellow power from light switch Red/white. High beams (all 4 headlights) Red/black. Low beams (2 outer headlights) Black. I assume this is the trigger wire that should shift the relay from low to high beams. Also have no voltage on the wires on the turn signal stalk for high/low beams but do have power to the turn signals wires (turn signals work) Thank you John Quote Link to comment
datzenmike Posted February 15 Report Share Posted February 15 Instead of Black I have a Red wire. Test the Black for power when the headlight switch is pulled out. Red/yellow power from light switch I think this goes to the light switch and is grounded Red/white. High beams (all 4 headlights) yes Red/black. Low beams (2 outer headlights) yes Quote Link to comment
Chief John Posted February 16 Author Report Share Posted February 16 Thanks for the help. I found another relay bolted to the fender well. It was old and rusty. I took it apart and cleaned the contacts and was able to see how it was wired. After reinstalling the headlights work perfectly. I now get high and low beams using the turn signal stalk controls. Thanks again John Quote Link to comment
Stoffregen Motorsports Posted February 16 Report Share Posted February 16 That's the beauty of old car parts - they can be taken apart and cleaned. Quote Link to comment
datzenmike Posted February 16 Report Share Posted February 16 Another oddity... Most Datsuns power the headlight relay off the parking lights. If your headlights are stuck on high beam check if the parking lights are working. On the headlight relay the default position is high beams. Without parking lights the relay can't select low beams. My '68 510 had no working washer pump. The original owner may not have ever used it as the wiper knob must be turned to work it. Took me a long time to figure this out. I took it apart (all tiny nuts and bolts) sanded the commutator, the copper was all corroded. Worked perfectly. My next Datsun was a new '76 B-210 and the electric motor was riveted together. Quote Link to comment
