nathan.is.an.idiot12312 Posted February 1 Report Share Posted February 1 okay so, i have 1981 datsun 210 4 door sedan with the nissan a15. i am currently running a weber redline 32/36, but i want to swap to a double 40 or 45 twin side draft carburetor setup, for looks, sound and better throttle response. is this possible? is this a good idea? will i make any extra power? Quote Link to comment
datzenmike Posted February 1 Report Share Posted February 1 It'll sound better but won't make a lot more power because the cam in there is a little mild and can't use all of the carburetor upgrade effectively. A medium cam upgrade would really help. Someone here can offer help on this. What goes in has to get out. What ever the exhaust pipe diameter is, replace with a custom one that is 1/4" larger. Doesn't take much for a big increase in flow. If you have a 1 1/2" pipe, going to a 1.3/4" is a 36% increase!!!!! more than enough. Next is a turbo style muffler. This is not an annoying straight through fart cannon but is filled with sound deadner and some baffling is far less restrictive than the stock quiet muffler and easier to live with. Header? This is up to you. The farther you go down the performance road the more a header will help. It does nothing around town and improves top end. Beware that they are expensive and will not last and eventually need replacing. Expensive ones that are ceramic coated will last the longest. Hang onto your old exhaust manifold in case you want to switch back in the future. If you don't have emissions testing and have a catalytic converter, get rid of it. Quote Link to comment
Stoffregen Motorsports Posted February 1 Report Share Posted February 1 Short answers. Nope Nope Nope It will sound good with a bigger exhaust, but it won't make any better horsepower without some port work and a cam and some distributor mods. Throttle response will likely be worse with the dual carbs than with the DGV. Not saying you shouldn't install them. Just explaining that there is more to it than that. Quote Link to comment
nathan.is.an.idiot12312 Posted February 7 Author Report Share Posted February 7 cool thanks guys 1 Quote Link to comment
