521 Driveshaft Removal
  • Replies 7
It's a splined joint. It should just pull apart. Mark so the splines go back exactly as they are now. Unless damaged/worn and the driveshaft now wobbles causing vibration I would just leave it alone.
If off the differential, try tapping on the yoke that holds the U joint.
@datzenmike
Ok I will mark it. Thanks for that. Wouldn't have known
It's not connected to diff on the other side.
I figured it would just pull out, but I guess that's just what happens with rust
If it doesn't come out, I'll leave it alone. Wanted it out of the way, but will work around
Thanks for the quick reply!
I was having a hard time understanding that picture, i had to go look at my old build pics... I had not idea that was a threaded cap there....
Mike what's the need for the cap there?
There is a grease fitting for that splined joint.... it should be able to slide in and out smoothly during suspension movement....
Does it move at all?
You could probably take that fitting out and spray pb in there .....
 It allows the driveshaft to compress and expand during suspension movement so needs grease on the splines. If worn there will be movement laterally at the spline. If so the balance will be way off and the driveshaft will vibrate. In forth the driveshaft spins at engine RPMs.
I had a 720 slip yoke in my 620 and it was making noise. The driveshaft shop told me what chev van had that was similar, found one in a wrecking yard and he converted it.
