Spacewalkingninja Posted December 12, 2023 Report Share Posted December 12, 2023 Yeah... my hearse started squealing due to old age, or it's missing the coffins? Not sure and I too am getting tired of dark humour anmd stupid jokes to lift myself up. I imagine that the 720 differential could be a good fit for my van? WHAT Nissan/Datsun differential would fit my 1982-86 Urvan E23 (SD23) Here are some schematics to look at.. https://nissan-europe.epc-data.com/urvan/e23/1583-lb/power_train/380/38454/ This was out of my bounds so I drove her to a mechanic I was recommended by a friend. The guy called me today and told me it wasn't the rear axle bearing, as I was thinking... and hoping. Unfortunately, they say, it is the differential that's squaling on my van. I am not sure how extensive the damage is, so I will be looking for the whole unit so we can build a diff out of the 2 units. Any help, appreciated 🙂 Quote Link to comment
Spacewalkingninja Posted December 12, 2023 Author Report Share Posted December 12, 2023 Well if this holds any truth, which I think it does.. The 720 diff should be a good fit. A confirmation from someone who understands this better than me will ease my inner fears, but here is the 720's rear schematic: both share a lot of parts, and mainly the ring and pinion so I think it isn't too far fetched to make it work. Quote Link to comment
datzenmike Posted December 13, 2023 Report Share Posted December 13, 2023 Top picture is the C-200 (ring diameter 200mm) used in the '83 and up 4x4 with 4.11 ratio only, bottom is the H-190. (190mm) 3.364, 3.545. 3.70, 3.889, 4.11, 4.375 and 4.625. Also the noise is most likely one of the three bearings and not the gears. Bearings are much cheaper to replace. Quote Link to comment
Spacewalkingninja Posted December 13, 2023 Author Report Share Posted December 13, 2023 yeah, you're correct about the pictures. Probably that website has some info wrong because I couldn't find a E23 SD23 Urvan rear diagram... Tomorrow I'll be going to the shop and I will talk to them & see if bearing replacement is an option. Main problem here is going to be finding the right parts. After some digging I found the reference 38311C6040 tied to a E23 Urvan diff, I'm not 100% sure mine will be the same... I will be searching with the info I find on mine. So far it appears though that the 38311C6040 is used in D21, D22 pickups, in nissan vanette's, Cabstar / Atlas trucks. If this holds true, it may be easier than they were telling me. Here is where I got hold of the reference> https://partslocator.com.au/1983/nissan/urvan/e23/lwb/5-sp-manual/20l-carb/diff-complete-rear/toowoomba/qld/7171481 Tomorrow I will make sure what exactly my van's got though Thanks! Quote Link to comment
datzenmike Posted December 13, 2023 Report Share Posted December 13, 2023 If the differential has a removable cover on the rear then it's a C-200. 38311- C6040 does not come up on my data base. However 38 indicates Final Drive Assembly and 311 indicates gear carrier so it's in the ball park. Quote Link to comment
None_zero Posted December 14, 2023 Report Share Posted December 14, 2023 Am I the only one who sees the irony of looking for a differential that is ...the same Quote Link to comment
datzenmike Posted December 14, 2023 Report Share Posted December 14, 2023 Why wouldn't you? Quote Link to comment
Stinky Posted December 15, 2023 Report Share Posted December 15, 2023 Actually, I think that he is looking for the same Differential Good point on your part Quote Link to comment
None_zero Posted December 17, 2023 Report Share Posted December 17, 2023 I just thought it was a fun pun. Lol question along this line. I noticed a couple days ago that a crunchy bad sound was coming from the rear of the 720 it's intermittent and happens most often when turning and while the bed has a couple hundred lbs of cargo. Also perhaps while driving uphill under load though it's less crunchy then. Is this probably my differential needing fluid or. Could it be the drum brakes finally giving up the ghost and getting stuck ? Quote Link to comment
None_zero Posted December 17, 2023 Report Share Posted December 17, 2023 (edited) Seriously though you guys don't get the joke or you're just messing with me? He needs a differential but he's looking for a different differential that has the same difference.... or rather he's looking for the same differential but a different differential will do as long as it's the same difference.. either way to me that's friggin hilarious Edited December 17, 2023 by None_zero Quote Link to comment
datzenmike Posted December 18, 2023 Report Share Posted December 18, 2023 Ahhh... differential! No wait, she's way too insincere, sorry. There. 1 Quote Link to comment
