BarryA Posted December 16, 2008 Report Share Posted December 16, 2008 driveshafts are interchangable? I need to go through the driveshaft on the KC - if KC & longbed units are identical, I'll swing by P&P and pull the one in the 79 longbed they've got, do the u-joints and center bearing/support on it, then swap it into the KC (no downtime). Quote Link to comment
datzenmike Posted December 16, 2008 Report Share Posted December 16, 2008 The wheel base is the same for long and KC. Frames are identical but for bed mounts. Quote Link to comment
Bleach Posted December 16, 2008 Report Share Posted December 16, 2008 Yes the driveshaft changes over. I used a longbed driveshaft on a Kingcab truck. Quote Link to comment
BarryA Posted December 16, 2008 Author Report Share Posted December 16, 2008 switch out of that 79 long bed, too - it's turned cold, my blower only works on high speed, and it's noisy. Quote Link to comment
datzenmike Posted December 16, 2008 Report Share Posted December 16, 2008 Look above the gas pedal on the heater box. There should be some Blue wires with Black ends that plug into this: http://i138.photobucket.com/albums/q251/datzenmike/electrical620heatertwospeedcoil.jpg[/img]"] Only the two blade connectors will show, and the wire wound resistor will be inside the housing where the fan air keeps it cool. Pop one out at a wreckers and pop it into your pocket. This will give you tour low speed. Quote Link to comment
