NICKLE&DIME2 Posted November 1, 2023 Report Share Posted November 1, 2023 Have a pressure plate Nissan oem still in Nissan box Nos. Not gonna use in my 510. Tried to list it on classifieds but won’t let me upload in picture/images field. 160.00 in Nor Cal part number 30510-19E00 Quote Link to comment
datzenmike Posted November 1, 2023 Report Share Posted November 1, 2023 30510 is not a pressure plate number, however 30210 is. I tried 30210-19E00 and it isn't a Nissan PP. 240/260/280z and most 280zx were 225mm pressure plates so it won't fit a 510 unless you have an L20B or Z series engine from a truck. Quote Link to comment
NICKLE&DIME2 Posted November 1, 2023 Author Report Share Posted November 1, 2023 Thank you, I will try to post pics soon. I bought for my 510, I have an l20 with 240z bell housing and guts from a sx standard H pattern that Rebello did in the 80s. I was hoping it was a roadster plate. On the plate it says Nissan and N-8353 89-9 atusugi also has these numbers 16e00, all character on pp are engraved including “Nissan”.. I’d be happy if I may use it for my car. I measured the back and converted to mm. Came out to 240mm. My brother saying it may be SR, or vg30. Quote Link to comment
NICKLE&DIME2 Posted November 1, 2023 Author Report Share Posted November 1, 2023 Quote Link to comment
datzenmike Posted November 2, 2023 Report Share Posted November 2, 2023 7 hours ago, NICKLE&DIME2 said: part number 30510-19E00 2 hours ago, NICKLE&DIME2 said: Thank you, I will try to post pics soon. I bought for my 510, I have an l20 with 240z bell housing and guts from a sx standard H pattern that Rebello did in the 80s. I was hoping it was a roadster plate. On the plate it says Nissan and N-8353 89-9 atusugi also has these numbers 16e00, all character on pp are engraved including “Nissan”.. I’d be happy if I may use it for my car. I measured the back and converted to mm. Came out to 240mm. My brother saying it may be SR, or vg30. Yeah, that's a lot better 30210-16E00 is the pressure plate from an '84-Jan. '86 FWD Maxima 5 speed with VG30E engine so yes very likely it's a 240mm. It's rated at 580Kg clamping force. Won't fit an L20B unless you install a 720 Z24, or a D21 Hardbody KA24E or KA24DE flywheel. Quote Link to comment
yenpit Posted January 10 Report Share Posted January 10 On 11/1/2023 at 7:50 PM, datzenmike said: Yeah, that's a lot better 30210-16E00 is the pressure plate from an '84-Jan. '86 FWD Maxima 5 speed with VG30E engine so yes very likely it's a 240mm. It's rated at 580Kg clamping force. Won't fit an L20B unless you install a 720 Z24, or a D21 Hardbody KA24E or KA24DE flywheel. The 280Z 2+2 was also a 240mm PP & disc, 6 bolt flywheel. Quote Link to comment
