240z pressure plate
NICKLE&DIME2
  • Replies 5
30510 is not a pressure plate number, however 30210 is. I tried 30210-19E00 and it isn't a Nissan PP.
240/260/280z and most 280zx were 225mm pressure plates so it won't fit a 510 unless you have an L20B or Z series engine from a truck.
Thank you, I will try to post pics soon. I bought for my 510, I have an l20 with 240z bell housing and guts from a sx standard H pattern that Rebello did in the 80s. I was hoping it was a roadster plate. On the plate it says Nissan and N-8353 89-9 atusugi
also has these numbers 16e00, all character on pp are engraved including “Nissan”.. I’d be happy if I may use it for my car. I measured the back and converted to mm. Came out to 240mm. My brother saying it may be SR, or vg30.
7 hours ago, NICKLE&DIME2 said:
part number 30510-19E00
Yeah, that's a lot better 30210-16E00 is the pressure plate from an '84-Jan. '86 FWD Maxima 5 speed with VG30E engine so yes very likely it's a 240mm. It's rated at 580Kg clamping force.
Won't fit an L20B unless you install a 720 Z24, or a D21 Hardbody KA24E or KA24DE flywheel.
  • 2 months later...
The 280Z 2+2 was also a 240mm PP & disc, 6 bolt flywheel.
