Datsun 720 4x4 front differential leak
Sergio146
  • Replies 6
The round thing is the side flange and using two pry bars across from each other just pry it out. There is a circlip that holds onto the side flange splines and prevents easy removal. The seal should be pressed into the side bearing retainer just behind it. You should be able to pry the seal out with a screwdriver. The new seal should be tapped into the side bearing retainer using a suitable size socket. Be sure to grease the seal lips before the side flange is fitted so it doesn't start turning dry.
The  side flange just pushes back into the differential and engages the side gear splines and the circlip.
