Still Breathin Posted September 29, 2023 Report Share Posted September 29, 2023 Hey folks been a while since I was on but ran into an issue while changing out my front rotors, I have always tightened my front wheel bearings by running the nut up & turning the hub until all slop is gone then tap retaining nut a bit tighter just to line up the slot for the retaining nut lock washer. However I like to check my shop manual prior to doing most jobs & it tells me I need to " set preload torque " I have NEVER had to do this before so I thought I would ask those who know, is this absolutely needed or will the way I have always done front wheel bearings work without messing something up ? Thanks ahead of time & if someone has already answered this I apologize but I need to know because snow will be blowing soon ! Quote Link to comment
datzenmike Posted September 29, 2023 Report Share Posted September 29, 2023 Removing all the 'slop' and then further tightening till the cotter pin goes in is rough on the bearing life. Assuming bearings are in good shape and everything fully greased... Tighten wheel bearing nut to 25-29 ft. lbs. Turn wheel several turns in both directions to seat bearing. Check nut torque is still 25-29 ft. lbs. Loosen nut 45 degrees. That's half of a 90. Install adjusting cap and tighten until any of the grooves aligns with the hole in the spindle. If this can't be achieved tighten the nut up to as much as 15 degrees and use a new cotter pin. I've never done this but... Using a fish scale pull sideways on any wheel lug and measure the effort needed to begin turning the hub. With new bearings ........ 6.4 pounds. With used parts.............. 2.2 pounds. Quote Link to comment
Still Breathin Posted September 29, 2023 Author Report Share Posted September 29, 2023 Datzenmike, I just wanted to say thank you for the info & taking the time it helps a bunch. Quote Link to comment
datzenmike Posted September 29, 2023 Report Share Posted September 29, 2023 That's right out of the '84 FSM. Most pre loads are similar, my '76 710 is close. Quote Link to comment
Stoffregen Motorsports Posted September 29, 2023 Report Share Posted September 29, 2023 Fish scale does help, but the numbers are pretty loose. You can run 6 lbs on old bearings without trouble, but you can't run 2 lbs on new bearings, or you'll be adjusting them again in a month or so. Quote Link to comment
DwayneOxford Posted September 29, 2023 Report Share Posted September 29, 2023 My method for old brgs. is finger tightening while turning drum/rotor, lock on next tighter spot. I'm 70, worked since childhood. 2 Quote Link to comment
