BvtnDave Posted September 4, 2023 Report Share Posted September 4, 2023 Here is a bit of mystery: So far, the usual suppliers are coming up empty in my quest to find the two-hole fuel line grommets for PL 510 that are located in the RF corner of the engine compartment (below the factory fuel filter location) and under the fuel tank where the lines pass through the floor of the car. Does anyone have a source for these? Thanks Quote Link to comment
iceman510 Posted September 7, 2023 Report Share Posted September 7, 2023 The best available is a Jeep floor grommet. Fits the hole size, but has no hole in it. I punched a hole in mine and glued it in place with some sealant because it was a little loose. 510 Realm thread: https://the510realm.com/viewtopic.php?t=15878&start=15 Link to ebay auction in that post is out of date, but you can find another of the same (Jeep JK JL). Quote Link to comment
iceman510 Posted September 7, 2023 Report Share Posted September 7, 2023 I realized today you may not be immediately able to access the Realm unless you are a member there. Here is an ebay auction for the new recommended plug: ebay jeep grommet Quote Link to comment
DARIN 510 Posted September 8, 2023 Report Share Posted September 8, 2023 I’ve used that before. It’s very close. But it doesn’t have the double lip to keep it in place. Tends to pop out on it own Quote Link to comment
iceman510 Posted September 8, 2023 Report Share Posted September 8, 2023 Yes. I applied a thin smear of RTV to mine to keep it in place as mentioned. Quote Link to comment
BvtnDave Posted September 13, 2023 Author Report Share Posted September 13, 2023 Thanks iceman510 and all who replied. The tribe comes through again. Quote Link to comment
