Jimbotonic Posted August 25, 2023 Report Share Posted August 25, 2023 Does the front wheel hub have an outer seal or a lock ring for the outer bearing? I’ve been looking at diagrams and videos and I’m not seeing one. Looks to me like there is just the washer, lock nut & cover, and pin. Any knowledge on this would be greatly appreciated. Thanks! Quote Link to comment
datzenmike Posted August 25, 2023 Report Share Posted August 25, 2023 Seal? well not like the inner one that presses in, no. The bearing is held in place by a washer, nut, nut cap, cotter pin. The only seal is the O ring on the wheel nut dust cap. There is also a procedure for setting the correct bearing pre load with the wheel nut before the cotter pin is installed. Quote Link to comment
Jimbotonic Posted August 25, 2023 Author Report Share Posted August 25, 2023 Thanks for the info! You don’t know the torque specs for the wheel but by chance? Quote Link to comment
datzenmike Posted August 25, 2023 Report Share Posted August 25, 2023 Bearing pre load? Tighten wheel nut 25-29 ft. lbs. Spin wheel hub several turns in both directions. Check nut is still 25-29 ft lbs. Loosen nut 45 degrees. Install adjusting cap so that cotter pin aligns with hole in spindle. If you must, turn nut in the tight direction (but not more than 15 degrees) till it does line up. Always use a new cotter pin. Quote Link to comment
Stoffregen Motorsports Posted August 27, 2023 Report Share Posted August 27, 2023 On 8/25/2023 at 6:08 AM, datzenmike said: Bearing pre load? Tighten wheel nut 25-29 ft. lbs. Spin wheel hub several turns in both directions. Check nut is still 25-29 ft lbs. Loosen nut 45 degrees. Install adjusting cap so that cotter pin aligns with hole in spindle. If you must, turn nut in the tight direction (but not more than 15 degrees) till it does line up. Always use a new cotter pin. Yes, use the proper method and you'll never have loose wheel bearings. You could also get a cheap fish scale to measure the preload. Should be about 6 to 12 pounds. Quote Link to comment
