DwayneOxford Posted September 24, 2023 Author Report Share Posted September 24, 2023 Top hole too small for gear? Quote Link to comment
datzenmike Posted September 24, 2023 Report Share Posted September 24, 2023 The spindle is supported above the gear by a bushing as it is probably pushed upward buy the crankshaft worm gear. If the spindle was installed from the top it would push up into the distributor is my guess. I pulled a high volume KA pump in the wrecking yard and was in such a hurry to see the oil pressure results I swapped it right in the parking lot. Naturally the damn spindle fell out and I had to find TDC and piss around getting the 11:28 setting. Spindle falling out with pump and timing chain tensioner falling out if you remove the cam sprocket are just two thing that the L series does. 1 Quote Link to comment
DwayneOxford Posted September 25, 2023 Author Report Share Posted September 25, 2023 On 9/24/2023 at 9:43 AM, datzenmike said: The spindle is supported above the gear by a bushing as it is probably pushed upward buy the crankshaft worm gear. If the spindle was installed from the top it would push up into the distributor is my guess. Yup, prob so. Some friction retention at dist. woulda been a nice touch. On 9/24/2023 at 9:43 AM, datzenmike said: I pulled a high volume KA pump in the wrecking yard and was in such a hurry to see the oil pressure results I swapped it right in the parking lot. Naturally the damn spindle fell out and I had to find TDC and piss around getting the 11:28 setting LOL, learning the hard way is rough but makes BIG impression and slows one up considerably. Quote Link to comment
