kyushasanonymous Posted July 19, 2023 Report Share Posted July 19, 2023 Hey guys. I’ve done a lot of digging and after discovering that my truck was already converted to a one wire GM alternator, I am sticking with it rather than swapping back to another style since I have all the provisions in place for it. My only concern is wiring. as it was, the alternator had wires coming off it going to the battery on both positive and negative. (Which worked fine) but I need to know what to do with the other wires. My truck is a 77 so has an external regulator. All 4 of the old alternator wires were just cut and taped into the other harnesses in the engine bay. Is there something cleaner or more effective that I can do with those wires? Quote Link to comment
datzenmike Posted July 19, 2023 Report Share Posted July 19, 2023 Not really, if tapped up I guess you could un tape them and cut them long to short and then spiral black tape them. This way there is not a noticeable clump. For a trip to a wrecking yard you can get harness covering, hides everything and also protects where chaffing may be a problem. Amazon has it but not that cheap. Quote Link to comment
kyushasanonymous Posted July 19, 2023 Author Report Share Posted July 19, 2023 Would it make sense to attach the WR and B wires to the positive and ground on the alternator just to have them tied to something or would it not matter? I’d like to remove the regulator since it’s just taking up space. I’ll get some pics posted soon. Quote Link to comment
kyushasanonymous Posted July 19, 2023 Author Report Share Posted July 19, 2023 On another note, is the black wire that is butt spliced into the red wire with the ring terminal (was on the positive battery post) fine? 1 Quote Link to comment
Duncan Posted July 19, 2023 Report Share Posted July 19, 2023 2 hours ago, datzenmike said: cut them long to short and then spiral black tape get a roll of actual harness tape to wrap them. If you use black electrical tape, it leaves a shitload of residue on the wires which is a literal fucking nightmare to clean off, The wires will remain forever sticky, and the shit is really hard to get off your hands.. I fixed that for ya, Mike.. 2 Quote Link to comment
