Too many projects Posted July 11, 2023 Report Share Posted July 11, 2023 I used to have a 82 720 with the SD22 and loved it had to sell it because money was short 20 years ago. Recently I cam across a SD22 engine with no transmission. I am looking for a bell housing to be able to start an engine swap. If anyone can point me in the right direction, I would greatly appreciate it. Quote Link to comment
620slodat Posted July 14, 2023 Report Share Posted July 14, 2023 I checked into a 6 speed transmission and i came up with a transmission out of a Mazda with a rotary engine. As I remember it was the same make as the Datsun, but I don't remember what year. The plus side was that the starter was in a reverse location on the transmission, not the motor. I didn't follow up on this transmission because I already had a starter and transmission that were good. The transmission may be worth checking out further to see if it will actually be something of value to the SD22. If you are into making things work let me know. Don Quote Link to comment
datzenmike Posted July 14, 2023 Report Share Posted July 14, 2023 This is going into a now gas powered 720???? Converting to diesel won't be easy, and won't be as powerful as the gas engine. Your current differential may not be a perfect match to take advantage of the SD's low speed torque. Only an SD transmission will have the starter in the SD location on the left. The 'bell' is incorporated into the front case half of the transmission. Probably just as easy to look for a complete SD 5 speed. The later SD25 transmission will also fit but '85 and on had a larger 62mm counter bearing so the hole in the front case is larger than the earlier 56mm bearing. Just pop the 56mm off and put a new 62mm bearing on the counter shaft. Quote Link to comment
