AE80Baby Posted June 22, 2023 Report Share Posted June 22, 2023 Hi everyone. I have an ae80 corolla with a 3a engine on it. My carb's gone bad and after looking around i was recommended to get an a15 carb by some and a b12 carb by others. Is there any difference between these 2 models somehow? Quote Link to comment
datzenmike Posted June 22, 2023 Report Share Posted June 22, 2023 What's a B12 carburetor??? You can rebuild the original carburetor. Kits are often available and there is little to wear out, mostly the accelerator pump. Most common things wrong with a carburetor is they are dirty and are out of adjustment. A simple cleaning will put them right. You need a work space, carb cleaner, paper towels, a camera, some small tools and a couple of hours. I assume Toyota issue factory service manuals? (FSMs) This would have all the settings. A used A15 carburetor is a crap shoot with other unknown problems and would likely need rebuilding anyway. A remanufactured carburetor from China just as bad. Best is the original Toyota carburetor but if impossible to find, one from a roughly similar displacement engine will work if it will fit your manifold, throttle cable connection, emissions, air filter, fuel line etc. Carburetors just mix fuel and air they don't really care what engine they are on. If I knew anything about the 3a engine I could hazard a guess about this. 1 Quote Link to comment
Stoffregen Motorsports Posted June 22, 2023 Report Share Posted June 22, 2023 Cheaper and easier to get a Weber DGV. 2 Quote Link to comment
datzenmike Posted June 22, 2023 Report Share Posted June 22, 2023 Yes, good thinking. Quote Link to comment
AE80Baby Posted June 22, 2023 Author Report Share Posted June 22, 2023 47 minutes ago, Stoffregen Motorsports said: Cheaper and easier to get a Weber DGV. about 2 hours after posting this i went ahead and bought one. Thanks for the help 2 Quote Link to comment
AE80Baby Posted June 22, 2023 Author Report Share Posted June 22, 2023 4 hours ago, datzenmike said: What's a B12 carburetor??? You can rebuild the original carburetor. Kits are often available and there is little to wear out, mostly the accelerator pump. Most common things wrong with a carburetor is they are dirty and are out of adjustment. A simple cleaning will put them right. You need a work space, carb cleaner, paper towels, a camera, some small tools and a couple of hours. I assume Toyota issue factory service manuals? (FSMs) This would have all the settings. A used A15 carburetor is a crap shoot with other unknown problems and would likely need rebuilding anyway. A remanufactured carburetor from China just as bad. Best is the original Toyota carburetor but if impossible to find, one from a roughly similar displacement engine will work if it will fit your manifold, throttle cable connection, emissions, air filter, fuel line etc. Carburetors just mix fuel and air they don't really care what engine they are on. If I knew anything about the 3a engine I could hazard a guess about this. Thanks for the help Quote Link to comment
