rattyrat Posted May 30, 2023 Report Share Posted May 30, 2023 hey yall, won a 510 at an auction. was running fine on inspection but since taking delivery it won't start at all. battery is fine. headlights work when ignition turned but signals aren't working at all on the front or rear. fan and other things working. it cranks but no start. new to all of this and don't know what to check next? could the engine be flooded? Quote Link to comment
datzenmike Posted May 30, 2023 Report Share Posted May 30, 2023 All lighting works without the ignition on. So should the brake lights and horn. What does gas gauge say? Needs the ignition on 1/ Take a spark plug wire off and put an old plug in the end and hold against the head or any grounded surface. Have someone try to start the engine. Got spark??? If yes then assume it's not electrical. 2/ Look at the front glass on the carburetor is it half full of gas???? Did you pump the gas pedal once to set the choke? 1 Quote Link to comment
rattyrat Posted May 30, 2023 Author Report Share Posted May 30, 2023 once i'm back home i'll check and let you know. also the car is a twin carb so not sure whether this a difference? and yes I did pump the gas to set the choke. i'm not sure what the transportation company did though so not sure if they could've screwed anything up when starting the car? i apologize if these are dumb questions Quote Link to comment
banzai510(hainz) Posted May 30, 2023 Report Share Posted May 30, 2023 check for spark from distributor cap center wire close to ground. to a 510 ownere this is a ez fix cause it was running. check for spark from center coil wire place near ground like the strut nut and start. see if spark. 1 Quote Link to comment
rattyrat Posted May 31, 2023 Author Report Share Posted May 31, 2023 14 hours ago, datzenmike said: All lighting works without the ignition on. So should the brake lights and horn. What does gas gauge say? Needs the ignition on 1/ Take a spark plug wire off and put an old plug in the end and hold against the head or any grounded surface. Have someone try to start the engine. Got spark??? If yes then assume it's not electrical. 2/ Look at the front glass on the carburetor is it half full of gas???? Did you pump the gas pedal once to set the choke? I have DM'd you with some pics and info :) Quote Link to comment
datzenmike Posted May 31, 2023 Report Share Posted May 31, 2023 BTW it looks like al L16SSS or maybe L18SSS engine... So forget pumping the gas and looking for the sight glass on a dual SU carburetor engine. Quote Link to comment
banzai510(hainz) Posted May 31, 2023 Report Share Posted May 31, 2023 (edited) 47 minutes ago, datzenmike said: So forget pumping the gas and looking for the sight glass on a dual SU carburetor engine. Starting fluid would help on that one for trouble shooting if it fires off with the starting fluid then ignition is good. then carbs (rocker arm lash maybe) Edited May 31, 2023 by banzai510(hainz) Quote Link to comment
