zeke5551 Posted May 29, 2023 Report Share Posted May 29, 2023 I know you've answered thsi question a million times, but I want to be sure. Putting my stock 260Z on the ground again with new tires. Had some wider slot mags when I bought it, but I have some 14 x 6 western 4 spoke flower mags to put on instead. What's the largest tire that will fit in the stock fender well with out changing the shocks? Thanks, Zeke Quote Link to comment
datzenmike Posted May 29, 2023 Report Share Posted May 29, 2023 Why would you change the strut??? You want the same, or close, tire diameter so performance and speedometer remains unchanged and simply go wider. As for rims you need to find out the off set of the rim. This dictates where the wheel sits in relation to the inside of the fender and the suspension. Too much negative off set and the tire sticks outside the fender and the body will come down on the tread on bumps, too much positive off set and the tire is set in too far and mar rub strut or spring. An 8" tire might fit but if too far in or out it won't work. Mount a rim and take a look. Will a 6" wide tire fit? Is there enough room to go to 7" or 1/2" wider per side? 8" maybe and 1" wider per side. 1 Quote Link to comment
zeke5551 Posted May 30, 2023 Author Report Share Posted May 30, 2023 Ok, what is the best diameter for a 260Z? The tires I have are too short, don't fill the wheel well Quote Link to comment
datzenmike Posted May 30, 2023 Report Share Posted May 30, 2023 Factory was 175 HR 14 what ever that is in diameter. Maybe 195/70R14??? 1 Quote Link to comment
Bleach Posted June 9, 2023 Report Share Posted June 9, 2023 yes, 195/70-14 sounds like the factory size. Your speedometer should read correct assuming the gauge and other items are functional. 205/60-15 is factory for 15 inch wheels (came on the 280ZX turbo) You can use a tire size calculator to figure out other sizes depending on what size of wheel you plan to use. Quote Link to comment
zeke5551 Posted July 8, 2023 Author Report Share Posted July 8, 2023 Thanks, used 195/70-14s on it and looks good 1 Quote Link to comment
