Webers on a FJ20E
bluke1
Some time ago I picked up a car with an FJ20E that was a basket case, and in the process of being converted to carbs. I have worked through the mechanical issues and now I need to find a distributor that will work in this setup. I'm using an MSD digital 6A and need to find an older 4 cylinder distributor that will work. I had one that I swapped the drive gear over to from the original but broke it when I dug in to check the mechanical advance mechanism, and can't remember which one I got. Possibly from an L series motor? Any suggestions?
  • Replies 3
