shirley Posted February 14, 2023 Report Share Posted February 14, 2023 My '81 720 recently started stalling on me when I stop. This happens when the truck is both cold and warm. No smoke and have not done anything lately to the truck. It has been colder(ish) here in sunny San Diego, so maybe it may have something to do with it. Any ideas? Quote Link to comment
datzenmike Posted February 14, 2023 Report Share Posted February 14, 2023 Yes 1/ Listen near the carburetor while someone turns the ignition switch on off on off on off, but don't start. What you should hear is a soft clicking sound. This is the idle cut solenoid that allows fuel down into the idle circuit. If not working the engine will run but won't idle. 2/ Separately pull one intake side and one exhaust side plug wires off and put a spark plug in the end. Hold firmly against the intake or exhaust manifold so it is well grounded and have someone turn the engine over with the starter. Is there spark on both intake and exhaust side plugs??? Both sides must be working for smooth idle. See if this helps narrow things down. There are more things to check so don't worry. Quote Link to comment
shirley Posted February 14, 2023 Author Report Share Posted February 14, 2023 Thanks! I can definitively do #1 but am having a problem understanding #2. Specifically the intake side and exhaust side wires and putting a spark plug in the end.... hmmmm....not sure how to do this. Quote Link to comment
DwayneOxford Posted February 14, 2023 Report Share Posted February 14, 2023 2 hours ago, shirley said: Thanks! I can definitively do #1 but am having a problem understanding #2. Specifically the intake side and exhaust side wires and putting a spark plug in the end.... hmmmm....not sure how to do this. You not have 8 plugs? Quote Link to comment
shirley Posted February 14, 2023 Author Report Share Posted February 14, 2023 Yes, 8 plugs. Quote Link to comment
datzenmike Posted February 14, 2023 Report Share Posted February 14, 2023 All 720 Z series engines were dual plug per cylinder with 4 on the intake side and 4 on the exhaust side. See below... Just unplug any wire on the left and the right side as seen from the front and check for spark. Quote Link to comment
shirley Posted February 14, 2023 Author Report Share Posted February 14, 2023 Got it! Thank you. Will give it a go. Quote Link to comment
datzenmike Posted February 14, 2023 Report Share Posted February 14, 2023 The dual plugs allows a shorter burn time so the timing can be reduced to like 50 BTDC. If one side is not working the timing would like to be about 10 to 120 so in effect the engine would be acting retarded and run very poorly. Quote Link to comment
shirley Posted February 14, 2023 Author Report Share Posted February 14, 2023 Makes sense. It's running pretty well, but the idle seems unstable. I was going to try to adjust it, but thought otherwise. I will keep you posted. Thanks! Quote Link to comment
datzenmike Posted February 15, 2023 Report Share Posted February 15, 2023 Well there is the idle speed screw and the idle mixture adjustment screw. Idle mixture only adjusts the idle mixture. On a thoroughly warmed engine, turn idle speed down as low as possible. This makes any changes more noticeable. Turn mixture screw in (lean) or out, (richer) till the idle drops off. Turn the opposite direction till it improves as much as possible. There may be half a turn where nothing seems to change so set roughly in the middle. Idle has probably gone up in response to the better mixture so turn it back down. Repeat the in and out adjustment of the mixture screw to find the best strongest and fastest idle speed. Again turn the idle speed down and repeat as many times as needed till you can't improve the idle quality any more and the idle speed is 700+- RPMs Quote Link to comment
bottomwatcher Posted February 16, 2023 Report Share Posted February 16, 2023 An unstable idle is usually a vacuum leak. Check your vacuum hoses. Quote Link to comment
shirley Posted February 16, 2023 Author Report Share Posted February 16, 2023 Yes, and some black smoke is also key to this, which I am having. Quote Link to comment
Landen_cesalYT Posted February 24, 2023 Report Share Posted February 24, 2023 On 2/14/2023 at 1:20 PM, datzenmike said: All 720 Z series engines were dual plug per cylinder with 4 on the intake side and 4 on the exhaust side. See below... Just unplug any wire on the left and the right side as seen from the front and check for spark. Aren't the intake plugs for emissions? Quote Link to comment
datzenmike Posted February 25, 2023 Report Share Posted February 25, 2023 Dual plugs are excellent for reducing emissions. But not just the intake or the exhaust sides. Both sets of plugs fire together all the time. Dual plugs shorten the burn time so the timing can be reduced. This shortens the time peak cylinder pressures are experienced and this reduces the production of oxides of nitrogen. Quote Link to comment
