Voltage Issue!!! Daily driver
hey guys, i got a big problem, i think. it started a few days ago. i have a '71 521 and the ign light came on, headlights are dimmer when it is on. but at 3000 rpms or so the light slowly goes out and you hear a yeeeeeaaaaart sound from under the hood. Voltage Regulator?? Alternator?? Ground??? stock everything besides electronic ignition, and weber carb. no stereo or nothing , any suggestions would be great!!!:blink:
  • Replies 3
Check the fan belt, it's loose. You can probably turn the fan blades by hand while the pulley slips. Loosen the alternator adjusting bolt and pry it away from the block till belt is tight and re-tighten bolt. The belt should move about it's width if you push hard with your thumb.
The belt might be 'glazed' too. It's worn until so shiny it slips. Replace it.
