darico246 Posted January 21, 2023 Report Share Posted January 21, 2023 I need the measurement for the bolt holes on the radiator support panel for the tension/castor rod brackets, from the chassis to the first bolt hole would do. The ones I have are like the s13 tension brackets and not the welded-on ones. The person replaced the radiator support panel and drill no holes, also I think it's a bit more supportive than buying a set of welded on brackets. Quote Link to comment
datzenmike Posted January 22, 2023 Report Share Posted January 22, 2023 I wonder what this is for? Quote Link to comment
darico246 Posted January 22, 2023 Author Report Share Posted January 22, 2023 Datsun 120y b310..i just need the right measurements to be sure before i drill holes for the bolt holes Quote Link to comment
KELMO Posted January 23, 2023 Report Share Posted January 23, 2023 Left side bottom. Left side, closer. Right side bottom Right side , closer. Should have turned that around. These were measured from the point where the hood ledge connects to the lower tie bar. Your lower tie bar looks completely different than what I have. If you need different angles or something else let me know. This is off of a 1979 210 4Dr sedan. 2 Quote Link to comment
darico246 Posted January 24, 2023 Author Report Share Posted January 24, 2023 huge thanks Kelmo..i used that photo so people can get an idea of what i meant but yu was spot on. cheers bro:) 1 Quote Link to comment
