ByStickel Posted January 19, 2023 Report Share Posted January 19, 2023 Saw a Diesel 5-speed trans for sale and wondered if those are L-series compatible. And what the internal ratios may be, wide or close ratio. Didn't immediately find what I needed on the webs. Thanks! Quote Link to comment
datzenmike Posted January 19, 2023 Report Share Posted January 19, 2023 The Maxima diesels were all automatics. If it actually IS from a Maxima it's an L series mid ratio with a 3.321 first gear as opposed to a 3.592 wide and a 3.062 close. If it actually IS a diesel 5 speed then from a 720 truck.... aaaaand the starter is on the driver's side. It will be a wide ratio but fits the SD series engines and not the L series... but... If you have an L series 71B 4 or 5 speed front case you could swap that on and convert it. Ask what side the starter is on. If on the right side get a picture of the top front taken from the rear. 1 Quote Link to comment
ArchetypeDatsun Posted October 8, 2023 Report Share Posted October 8, 2023 On 1/18/2023 at 8:20 PM, datzenmike said: The Maxima diesels were all automatics. If it actually IS from a Maxima it's an L series mid ratio with a 3.321 first gear as opposed to a 3.592 wide and a 3.062 close. If it actually IS a diesel 5 speed then from a 720 truck.... aaaaand the starter is on the driver's side. It will be a wide ratio but fits the SD series engines and not the L series... but... If you have an L series 71B 4 or 5 speed front case you could swap that on and convert it. Ask what side the starter is on. If on the right side get a picture of the top front taken from the rear. Actually diesel maxima came 5 speed too. Quote Link to comment
datzenmike Posted October 8, 2023 Report Share Posted October 8, 2023 Yes my mistake. Mid ratio for sure for gas or diesel. Quote Link to comment
