Gechie Posted January 19, 2023 Report Share Posted January 19, 2023 Datsun B-310/210 Running light fuse breaking each start of the engine... Maybe a short circuit... I read on a wiring diagram that it's the red w/ green stripe wire. I see that my red w/ green stripe wire under the steering wheel disconnected from wherever it was plugged in at. Anyone know where it might have disconnected from? Quote Link to comment
datzenmike Posted January 19, 2023 Report Share Posted January 19, 2023 There's probably more than one Red/Green wire. Be sure this is the correct one. Being disconnected won't blow the fuse. I would confirm that you have the correct amperage fuse. Can I assume that the running lights (front and rear parking lights, license lights, clearance lights and dash lights) are fine being on without the engine on??? I would get a meter and check the engine running charge rate across the battery terminals. Maybe the alternator is over charging??? If (for example) 18v that 50% more current flowing than 12v with engine off and might be enough to blow the fuse. Quote Link to comment
Gechie Posted January 19, 2023 Author Report Share Posted January 19, 2023 Even just turning the key to accessory mode blows the 15A fuse... 😂 I also might not be an electrician Most likely have to go to each red w/ green wire and just look to see if it roasted somewhere or just disconnected... Or would there be more going on than that? Quote Link to comment
Gechie Posted January 19, 2023 Author Report Share Posted January 19, 2023 But yeah the front headlights usually run with rear running lights when you turn anything on ignition-wise Quote Link to comment
datzenmike Posted January 19, 2023 Report Share Posted January 19, 2023 1 hour ago, Gechie said: But yeah the front headlights usually run with rear running lights when you turn anything on ignition-wise The headlights and running lights turn on with the ignition???????? what???? Quote Link to comment
Gechie Posted January 19, 2023 Author Report Share Posted January 19, 2023 Like normal it's all still stock I believe, so maybe when it's fully turned on the running lights then work but as of right now just brake lights work Quote Link to comment
datzenmike Posted January 19, 2023 Report Share Posted January 19, 2023 You haven't answered one of my questions. 1/ Did you check that you have the correct fuse amperage??????? Headlight switch to first position. Front and rear parking lights, license lights, clearance lights and dash lights all come on normally???? YES???? 2/ Does the fuse blow???? Quote Link to comment
Hawaiian620 Posted January 19, 2023 Report Share Posted January 19, 2023 (edited) 18 hours ago, Gechie said: Even just turning the key to accessory mode blows the 15A fuse... Is this with the lights off? Are you sure having your lights on is blowing the fuse? If you leave your keys out and turn on your lights does the fuse still blow? Edited January 19, 2023 by Hawaiian620 Quote Link to comment
