Oil pan needed for Z20 into a 1959 Morris minor
I am installing a 1980 Z-20 and automatic trans into my 1959 Morris Minor.  It has the front sump oil pan.  I need  a  rear sump oil pan and the pick up tube.   Does anyone have one?  Are there any cars I can get one from the junkyard?  Or am I fabricating a pan and sump?
Thanks, Dave
  • Replies 5
The front of the 2wd 720 truck Z20/22/24 oil pan is shallow at the front to clear the steering and a cross member to support the torsion bars. The pan is  deeper at the rear. You'll need the matching oil pick up tube. '81-'82 are Z22, '83-'86 are Z20 and Z24.
I  have an oil pan and should have the pickup tube also from an '81 720 Z22 2wd, pretty much exactly what Mike said.  Should be what you are looking for.  I'll give you a good deal.  Message me if you are interested.
